Check Engine
Old Aug 26, 2005 | 06:45 AM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
Check Engine
okay the check engine light was on in my car for about 10 years now it seemed... everytime i ran it through the scanner it was brought up to be the MAF Sensor.. i bought a new one.. NOT CHEAP... and it was the same.. i didnt know what to do.... i just started going on to everything people wanted 400 dollars to fix it... etc etc prices werent looking cheap until oneday i thought doesnt this have a RELAY? and yes i was right... it did it has 3 i bought the MAF sensor Power Relay.. swapped it out and my check engine light problems have been solved.... and all the relay cost at GM is 11 dollars... wow what a pain in the ***... i posted this cuz i know of alot of third gens with the check engine MAF sensor problem.. so before you go out and spend hundreds of dollars trying to get it turned off... try the relays...... trust me if thats all it is you saved your *** a whole lot of cash.. the MAF sensor alone was 180 after taxes and ****..... hope this post helps someone.....
Old Aug 26, 2005 | 05:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Welcome to thirdgen.org!
A search through this site would have yielded the same results
Old Aug 26, 2005 | 05:31 PM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
yeah i know... i just barely found out about this site about a week ago...
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
