heads
Old Sep 5, 2005 | 09:57 PM
icanfly's Avatar
heads
will a set of aft heads bolt on to an 89 iroc with a 350 tpi setup will the same lower intake work also im looking for 300 flywheel hp will these heads and a cam deliver what i am looking for just curious as to what all i am gonna need to make this swap work thank you for your info guys
Old Sep 6, 2005 | 03:46 PM
icanfly's Avatar
sorry that was A F R heads not aft heads my bad anybody running these are they a direct bolt on???
if not what heads are a direct bolt on???
Old Sep 6, 2005 | 04:22 PM
Doug Gulley's Avatar
Car: A Black One
Engine: 383 Chevy
Transmission: Retro T56... :>)
If you order the heads from AFR they can make them any way you want. Early or late bolt angles, perimeter or centerbolt style valvecovers, etc.
The AFR heads are way overkill (and expensive) for "just 300" flywheel HP.
They would be a great head if you planned on major engine mods if the future.
If you're going to be satisified with 300 HP and you're not concerned with emissions compatability, then I'd look for a set of Vortec heads
Old Sep 6, 2005 | 04:30 PM
kevinc's Avatar
Car: 1982 Z28
Agreed that AFRs aren't a great investment by themselves...you'd need to upgrade the cam and exhaust system to get much benefit out of them.
The Vortec head idea is a good path if the guy knows to buy a compatible intake base to go with them.
Old Sep 7, 2005 | 08:11 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
vortech heads are a good idea for 300 hp, for the price you could get the intake, headers, and the heads for less than the afr heads alone would cost maybe squeese a cam in the budget as well. not to mention the little things no one tells you you need when you use the afr heads I love them but, they are over kill for what you want
you will need to do some shopping around but, you could go way under the budget if you look at all used stuff but, the cam
http://www.sallee-chevrolet.com/Cyli...ds/Vortec.html
http://cgi.ebay.ca/Chevy-vortec-to-t...spagenameZWDVW
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
