need some place to start [noobie]
Old Sep 6, 2005 | 02:31 PM
trkklr77's Avatar
after a few weeks of reading and seeing what every one is doing i need some suggestions on what to do with finalizing my swap preporations.
this is all going in to a 77 4x4 truck with a manual tranny
i am planing on a maf setup, cause i cant find a way to get my speedo converted to the vss. is it posible?
what would be the best comp to use with the painless harness with #9 injetor?
what is the overall opinion of the mega squirt?
can i live with out some sensors like oil presure switch, lowtemp sensor, i know i need the knock,maf,temp, oil presure sender.
i will add more as i come up with them.
Old Sep 6, 2005 | 03:28 PM
kevinc's Avatar
Car: 1982 Z28
Re: need some place to start [noobie]
Step 1: read the Board Guidelines posted above, especially this part.
"Stay on-topic to each specific board/post and discuss Third Generation (1982-1992) F-Bodies (Camaros and Firebirds) only."
Step 2: go find a board where trucks are the topic...
Old Sep 6, 2005 | 07:31 PM
trkklr77's Avatar
i appologize. i wish you guys had a noobie section.
ill change it.
lets say i want to do a isolated system, all mechanical guages with and old 70's block.
what is a good comp for this setup?
what sensors can i bypass?
has any one tryied a diiferent manual tranny than the t56, how did you get a vss on it?
Old Sep 6, 2005 | 08:13 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
why should we have a noob forum. its a 3rd gen camaro site. If you wanna put a cam in a truck, go small, it makes a ton of tq.
Old Sep 6, 2005 | 08:19 PM
trkklr77's Avatar
ok i apollogize and hearby end this thread.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bamaboy0323
Sep 3, 2015 06:07 AM
