Idle Trouble
Old Sep 22, 2005 | 09:39 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Idle Trouble
I'm beginning to realize that when the fellow that put my 355 in bolted everything back on from the 305 tpi said he did it in his spare time, might should have raised a red flag or two. My question is (among other problems) I CANNOT get the car to idle; it will bounce between 1200 and cut-off. I have replaced the IAC motor and temp sensor (on the right side of the block) with new ones for a 350. I'm wondering if I need to replace the knock sensor, TPS sensor or anything else. This kind of coincides with my question below about upgrading my TPI/air intake as this seems more of a repair than an improvement.
HELP!!!
Thanks, Eric
Old Sep 22, 2005 | 05:14 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
check timing, fuel psi, and fuel injectors.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
