gas peddle to floor to start, help!!!
Old Sep 23, 2005 | 08:16 AM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
i have a problem,i have to floor the gas peddle to get my car to start. it's a 1990 ta 350 speed density. i have changed thi iac, the map sensor, and the tps. even after the car starts it still run a little rough untill it warms up. any help?
Old Sep 23, 2005 | 09:01 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
sounds like it may be flooding? i know that is a general rule for carbs is if you have to press it to the floor itis because ussually it is flooded.. with a tpi i am not positive though...
Old Sep 23, 2005 | 09:23 AM
Car: 1990 trans am
Engine: 350 tpi
pretty sure its not flooded because i have to do this every time even though its been sitting.
Old Sep 23, 2005 | 10:05 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My car had the same problem. 305 86 TPI. I can't for the life of me remember what the problem was. I would crank it, it wouldn't turn over, then I'd push the pedal down and it would start right up. Maybe a worn/dying out MAP sensor? Change your PCV valve? Oh I remember- changing my fuel filter is actually what fixed it but it sounds like that may be a different issue. Leaky injectors is possible as well.
Old Sep 23, 2005 | 11:33 AM
Yes. if you have leaky injectors then reguardless of how long you let it sit it would still have a little bit of a flood effect.
Old Sep 23, 2005 | 11:34 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
When you push the pedal all the way down during cranking there will be no fuel put in.
When the TPS is greater than 80% IIRC, there is "flood clearing" type of thing in effect. Your injectors may be leaking down and the fuel is already too much so when stopping additional fuel from entering, the motor starts.
This is only in effect during cranking below 300 rpm. After that the fuel runs normally.
Old Sep 23, 2005 | 11:38 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
With Fuel Injected cars, the correct starting procedure is to keep your foot OFF the gas pedal until it starts.
Old Sep 23, 2005 | 12:19 PM
Car: 1990 trans am
Engine: 350 tpi
of course but no peddle and it will crank till the cows come home and no start. a little peddle and no start. peddle all the way to the floor and it starts albeit hard.
Old Sep 23, 2005 | 01:05 PM
DJP87Z28's Avatar
I would start by checking the fuel pressure with just the key on, it should be between 36/38PSI. if not, you have major problems.
Old Sep 23, 2005 | 01:13 PM
Car: 1990 trans am
Engine: 350 tpi
how would i go about cheacking for a leaky injector?
Old Sep 23, 2005 | 01:39 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Install a fuel pressure gauge, turn the key on and off a few times so the fuel pump builds up full pressure, and watch for any significant loss of pressure on the gauge after a minute or two.
Old Sep 24, 2005 | 11:13 AM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Same thing happened to me with a bad IAC valve. Try unplugging it and see if it starts. That may or not tell you if it is bad. If that does not work you would have to measure the length of the pintle to plunger (look in a repair book) if the length is too long you will have to adjust it or get a new one. Mine was stuck in the closed position so I could only get enough air in to start it when I pressed on the gas to open up the throttle body.
Its worth a try...
Old Sep 27, 2005 | 03:58 PM
Car: 1990 trans am
Engine: 350 tpi
finally found my problem. for some reason the timing was all out of wack. thank for all your help every one.
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
