injector x ci
Old Sep 28, 2005 | 10:23 PM
trkklr77's Avatar
injector x ci
i have found alot of ebay deals lately claiming to be 350 units, most of them are coming up with 305 injectors. alot of time the seller is saying the unit are from 350's.
so flat out, will the 305 19# [or even the svo] support a 350?
Old Sep 29, 2005 | 10:13 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
yes
Old Sep 29, 2005 | 05:40 PM
trkklr77's Avatar
will they barely fed it or are they good for a stock motor?
Old Sep 29, 2005 | 07:12 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
They will be good for a stock motor. I had 24 lbs injectors in my 350. All it had was a cam exhaust and some other junk. and those injectors were a little big.
Old Sep 29, 2005 | 07:31 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
if you use the 19#'s.. you need to change the tables in the chip..
Old Sep 29, 2005 | 08:00 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Killjoy I bet if you bump the fuel pressure up a little it would work fine.
Old Sep 29, 2005 | 08:45 PM
cdartz's Avatar
No you don't change the tables. You change the injector constant.
Old Sep 30, 2005 | 10:30 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
yeah thats what i meant.. sorry... damn computer lingo..
Old Sep 30, 2005 | 10:38 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'd think the PE and AE stuff would require some major re-working in addition to the injector constant, as well. But then I'm no DIY guru, either.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
