vortec heads
Old Oct 4, 2005 | 11:11 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
vortec heads
ok, so this might be a stupid question, i know.
what heads came stock in 88 on a 305 tpi?
somewhere i heard they might be vortec heads, sounds wrong to me.
if it is wrong, will i be able to put a set of vortec heads on my motor and still run my tpi???
just wondering.
Old Oct 5, 2005 | 07:12 AM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
no there not vortec's on your car
try doing a
Old Oct 11, 2005 | 06:21 PM
purpleZ-28's Avatar
ok, i did not think so.
is it possible to put them on and keep my tpi?
Old Oct 11, 2005 | 06:25 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
yes, you have to by the intake base for vortecs.
http://www.sdpc2000.com/catalog/1460...-Baseplate.htm
Old Oct 11, 2005 | 07:47 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If you were to get vortecs on your tpi car, you would need a vortec tpi base. If you go with the 305, ported tpi, vortec head, that baby is gonna rev a ton better than your stocker.
Old Oct 12, 2005 | 09:21 PM
purpleZ-28's Avatar
well ****. $400 aint bad. plus it gives me the chance to powdercoat my intake while i wait for the base to come in.
has anyone done this to their car? know about the power gains?
Old Oct 13, 2005 | 12:48 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
How about power gains????
I just picked up a pair of vortec heads and a TPI setup for my car and am simply going to have the manifold bolts redrilled. Then, a friend is going to port match everything. What is the expected power increase? Approximatly...
Also a possible stock LT1 cam...
Old Oct 13, 2005 | 12:50 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I'd look into that more, you can make a stock TPI manifold work with the vorted heads.
Old Oct 13, 2005 | 03:42 PM
Spectre's Avatar
Engine: 3.0L/183
the vortec head ports are taller then the normal sbc head.
thats why you need a dedicated intaje maniforl.
Old Oct 15, 2005 | 09:45 PM
Shagwell's Avatar
Car: projects.......
if you run double gaskets or thick enough gaskets, the intake will sit high enough to be even w/ the port. I've done it twice now.
Old Oct 16, 2005 | 03:19 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Yes, you can make a stock intake work, though not very well. Got a friend that did it. He loves the vacuum leaks that came with it. He covets my SDPC intake, maybe he'll get it when I move to a StealthRam.
Old Oct 16, 2005 | 04:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Well I know a guy who tryed to "make it work " and he ended up with a 14.7 .... this was a vortec headed hotcammed 355 with a Barry grant 750 on it . It realllllllly cuts off the flow .
Old Oct 16, 2005 | 06:50 PM
purpleZ-28's Avatar
if its so troubling to make a stock intake base work, why not just buy the vortec one? if you got the cash bucks to drop on the heads in the first place it shouldnt be that big of a wallet killer.
Old Oct 16, 2005 | 07:31 PM
I bought my vortec heads for $500... oh, no, wait $50 sorry added a zero. And my TPI... $50.. Plus complete gasket set...$20 Grand total spent $120..
Old Oct 16, 2005 | 08:00 PM
purpleZ-28's Avatar
yeah vortec heads arent exactly pricey.
but whered you get a tpi unit for $50?? ive been looking at em, and theyre most in the $130 range, and who knows what kind of condition.
Old Oct 16, 2005 | 08:12 PM
EBAY!! The guy had his title as
"Complete ChevroletTune Port Injection" note, no space.
There where 18 views at the end of the auction, 6 of them where mine. And he was close by.
Old Oct 16, 2005 | 08:39 PM
purpleZ-28's Avatar
damn, ive been lookin on ebay for awhile. most of the systems i find are incomplete though
Old Oct 17, 2005 | 03:57 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
I have a camaro performers magazine that has the SDPC article in it for when they first introduced the TPI vortec manifold. With just the head swap from the L98 heads to vortecs and the tpi base the horse power went from 245hp to 305hp. That was with the stock L98 cam and no other bolt ons. Thats about the same horsepower the LS1 was making when it first came out. When they added an LT4 hotcam and a set of headers, (17/8 headmans or hookers, i dont remember) a set of 1.6 roller rockers, a set of edelbrock high flow runners and a 52mm throttle body they got up to 356 hp (285 hp at the rear wheels) I liked the way the set up ran and im almost done with a similar build up, although i dont believe ill get those numbers being that i dont have the same cam ( a bit more milder than the lt4). Just thought id give an idea on the subject from an article that has helped me make my decision at the time.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
