Good uprade from stock?
Old Oct 8, 2005 | 08:13 AM
koll's Avatar
Car: 1991 Pontiac T/A Vert
Currently the 350 TPI in the TA is stock (except for exhaust work). I was considering on putting a StealthRam for vortech heads ($300), Fuel Rail for SR ($184), Vortech Heads ($500). Thats about $1,000. If I decide on which one I was thinking cam too (Like this one Comp Cams 276 Hydraulic Roller Camshaft, 220 / 230, .510 / .510 114 LSA) ($200)
That'll be $1,200.
Is this a good way to spend 1k/1200 or does someone have a better way to spend 1k/1200?
Old Oct 8, 2005 | 08:28 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Sounds good to me. Just don't forget to factor in all the hidden costs, like heads gaskets, fuel lines, timing set and prom burning stuff.
Old Oct 8, 2005 | 08:33 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Fuel lines, if steel braided, will run you about $60. I actually am about to order from American Street Rod Performance Products, they have great prices on hoses and fittings.
Lots of gaskets are involves if you do all of that stuff, expect on purchasing a full gasket ki- maybe another $100.
Then you'll find you need a breather here and a new hose there, it really adds up. I don't want to sound discouraging, but just don't underestimate the cost and get stuck halfway through.
Old Oct 8, 2005 | 12:50 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
That would be a nice High-revving 350. Your going to loose a decent bit or torque though with those heads, cam and SR, but will make a TON more power above 4500 rpm than TPI.
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 19, 2015 01:36 PM
