My new 305 tpi
Old Oct 16, 2005 | 10:13 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
My new 305 tpi
Finaly its almost done, i only need to find a new radiator.
Its a 1986 305 tpi bored 0.030 and the crank 0.010
New sealed power pistons and rings and this camshaft http://store.summitracing.com/defaul...=KeywordSearch
I used the heads from the old 305 from 1988
I also have flowtech hedders, 3.5 inch exhaust , kn filter, airfoil , bbk AFPR , ported plenum , TB coolant bypass and a custom made prom for the computer . And ofcourse transgo:S shift kit for the tranny. I cant wait to start her up.
Heres some pics
Old Oct 16, 2005 | 01:08 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
nice to see that everyone is not afraid of a 305. I am about to rebuild mine with a .060" bored over pistons. I am going to do a real high duration cam with a medium lift as well. I am going to use the LT1 heads & intake. I believe I should be making some excellent power. Keep posted on results of your set-up. If your car is running properly you should break into and probably out of the 13's easily.
Old Oct 16, 2005 | 03:57 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I would've gone with a slightly different cam. For another $30 or so you could have gotten a CompCams XE grind.
As for that 5.0L LT1 that you plan on building...have fun with it. I absolutely loved mine for the few days I had it before I over-revved it (stock 90k mile bottom end doesn't like 6300rpm apparently ). I'll PM you about it and see if I can't help you out with anything at all.
Old Oct 16, 2005 | 04:22 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah im hopping to make some more hp , and the cam is alot better than the stock one so thats an improvement.
I hope to find a better rear end than the stock 2.73
I found a used radiator so now im almost done.
Old Oct 16, 2005 | 04:53 PM
Car: 1997 Corvette
Definitely agreed that its better than the tiny stock one. Should breathe well. Nice looking motor too. I love that polished TPI setup. Looks amazing
Old Oct 16, 2005 | 05:37 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by DuronClocker.(stock 90k mile bottom end doesn't like 6300rpm apparently ).
Old Oct 17, 2005 | 02:53 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yea i love the polished look but it can be better so ..
Its pretty easy to do but time consuming.
Old Oct 17, 2005 | 10:05 AM
banditfirebird's Avatar
Car: 04 Dodge SRT-4, 91 formula firebird
Engine: 2.4 L4, 305 tbi
Transmission: 5-speed, 700 r4
the motor looks awsome! try to post dyno results if u run it!
Old Oct 17, 2005 | 04:11 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yes i hope to do so.
Old Nov 7, 2005 | 01:07 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I started the new engine yesterday and it runs great , feels very strong so now i cant wait for the summer to show up.
Old Nov 7, 2005 | 02:05 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Blowing a motor apart at 6300 rpm is strange. I've seen several motors one a 305 and two 350s on the dyno with factory bottom end turning 6500 rpm on several occassions. I had some transmission problems on my old IROC and pegged the tach at 7000 and they all survived. Althought I will say the bearing problem was made demonstrably worse on my car after revving it to 7000rpm
Old Nov 9, 2005 | 12:53 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Old Nov 9, 2005 | 12:56 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
We made a little movie during the first start-up attempts. So if you want to listen and look at my car visit http://www.area51.org.il/~zaphodb/IROCZ/Scania/
And download the divx.avi version it wont take that long to download it.
I think the car sounds great.
Old Nov 15, 2005 | 10:54 AM
305TA85's Avatar
Have you drove it yet? What kind of fuel pump and injectors are you using? I am building my 305 soon.
Old Nov 16, 2005 | 11:20 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I have to wait until spring before i take it out on ´the road but as you can see in the movie the engine runs great.
Fuel pump and injectors are stock.
Old Nov 17, 2005 | 05:01 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
That looks awesome, I am not knocking you or any thing but what was your reasoning behind keeping the 305?? Trust me, I love my 305 I was just wondering your reasoning behind it. Also nice to see you kept your AC.
Old Nov 17, 2005 | 05:35 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Looks very nice, keep it goin'
Old Nov 18, 2005 | 02:45 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
A 350 cost a lot of money in Sweden. I got the 305 for free so thats why. And i should be able to play with the stock 350tpi :s soon.
Old Nov 18, 2005 | 03:49 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Same here, finding something bigger is hard work
Theres a 350 on e-bay atm it says "going cheap" and its already up to £1020, getting on for what i paid for my whole car.
As i'm not going drag racing the 305 is also slightly more economical, [lol 5ltr economy] and its a big motor here.
It does look like you put a lot of hard work in, and i can understand you waiting till summer, your road gritters are 10x worse than ours, it plays havoc with alloy and bodywork.
Old Nov 19, 2005 | 05:10 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Looks good. I would have gone for a little more cam, personally.
D/L the video now...all 415 megs of it.
Old Nov 19, 2005 | 08:39 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yes im sorry about the 415 megs , there where a smaller divx version but its gone . I have to ask my friend why since hes hosting the video for me.
I think this cam will be fine as it is.
Old Nov 19, 2005 | 09:25 AM
Scheister's Avatar
Car: 85 IROC
are you planning on taking it to a track or putting it on a dyno? id like to see what kind of numbers you make
Old Nov 20, 2005 | 11:36 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Im going to use my friends computer and log whats going on during a drive . And then the computer can tell you pretty good how much HP it makes and 1/4 mile times and 0-60 mph etc.
Old Nov 20, 2005 | 02:23 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
some guys in europe with these cars??????
Old Nov 20, 2005 | 02:41 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Nah, there's just a European section in the regional boards to make it look like some of these cars were sold/sent out of the North American region.
Old Nov 20, 2005 | 03:02 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
You mean they were'nt made here?????
Old Nov 20, 2005 | 03:57 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Well a friend of mine lived in the UK for about 5 years he said getting a camaro/transam over there was next to impossible. He said in his 5 years there he saw one. I find that surprising. I knew hte market for cars like that was non existent over there but I had no idea it was that weak.
Old Nov 20, 2005 | 04:09 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Well to be fair, you dont see them everyday, petrol costs are high for one. There are very few dealers, and they dont support the old models, so parts are never next day, like it would be with say a UK built car, etc etc if your off the road. [sometimes ] That, and its an old car to start with.
I can almost get parts for my TA delivered from the US faster than i can get spares for a Renault or Fiat, so its better than years ago.
But if you look through e-bay and Autotrader, theres always quite a few popping up, the Pontiac UK Owners is mainly made up of 2ndand 3rd gen Firebirds\Camaros.
But the fact they dont pop up round every street corner makes it nice when everyone looks twice at it.
Old Nov 20, 2005 | 04:11 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Well to be fair, you dont see them everyday, petrol costs are high for one. There are very few dealers, and they dont support the old models, so parts are never next day, like it would be with say a Ford, etc etc if your off the road. [sometimes ] That, and its an old car to start with.
So they actually like your car over there? Most of the folks over there hate most US built vehicles. At least thats what my friend said. All the guys he went to school with despised most fords, chevys and chrysler products. Everyone drove Audi, BMW, or Jap stuff. but he did go to cambridge so maybe thats why?
Old Nov 20, 2005 | 04:22 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Well a lot of younger kids point and shout "look its Knight Rider" !! [mines red but they are sort of right].
Not everybody despises them, i think maybe at Camebridge and a few other places, but people that want big engines, and solid [sometimes old fashioned] engineering really enjoy them, and looking at them.
You have to remember, a Rolls is about the largest car built here, and due to our roads, its not that big really.
So when i point out mine is the equivalent of what would be an MGB, people are quite impressed.
I would'nt mind, but most modern cars from most countries are all compacts [ie:Ford Mondeo, built for the world market] and they are all looking just like the wind tunnel says they should, i'm just glad mine is different.
Old Nov 20, 2005 | 04:28 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
I got ya
I'm trying to find a 3rd gen myself and holy hell its downright impossible to find a good 90-92 IROC/z28 with the 5 speed and the 5.0 TPI and be in good condition. Been looking about a month now but hell even in nationwide searches it only returns 5 or 6 cars that "might" be worth taking a look at. owell, hopefully in the next few months something will turn up
Old Nov 21, 2005 | 11:46 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
American cars are very popular in Sweden, and its fun to drive a "rare" car , everybody looks at you when youre out on the road.
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Old Nov 23, 2005 | 03:38 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Anybody want to take a guess how much HP the new engine has ???
Old Nov 23, 2005 | 03:47 PM
Engine: 388 Carb
Axle/Gears: 4.10
Ohh thats a tough one, I have heard that the GTech Pro is pretty accurate. I am getting one for christmas
Old Nov 23, 2005 | 03:51 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah i hope Santa is nice to me this year.
Old Nov 23, 2005 | 03:53 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
I got ya
Iam selling mine pretty soon for about $3500, but dont know if you would want it
Props to Scania for building such a sweet ride
Old Nov 29, 2005 | 05:38 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
LOL
This happended to me once when I had a black '97 Grand Prix GTP
Most people say to my Camaro its a trans am, thats the only car they know...
@Scania: You don't have problems running headers in Sweden?
Old Nov 29, 2005 | 10:53 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
No i removed the air thing and installed the hedders . No problem since its a pre 1989 vehicle and they dont test the emissions except for the CO . So i dont need to have a cat to pass the inspection.
Old Nov 30, 2005 | 01:30 AM
Car: '91 Z28
Engine: LB9
I think I have to move to Sweden...
Less crap with the inspections (and beautiful girls... )
Old Nov 30, 2005 | 05:22 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I'll take a stab at 240-250hp w/ pretty good torque. I'm thinking it has some power tied up in the stock TPI base and runners though.
I had nearly the exactly same setup in my 86 IROC, same exact cam specs, Edelbrock headers, ported plenum/matched runners, chip, etc. Main difference was mine wasn't a fresh rebuild on the motor but the tranny was fresh w/ a 2000ish stall and 3.42 gears out back.
It ran decently, pulled on a couple stockish 5.0 Stangs and a couple early 4.6l Stangs. I believe I pulled a lenght or so on a early C4 Vette one time, I assumed at the time it was a early L98 car but it could have been a crappy crossfire Vette for all I know.
I've since passed it on to my younger brother. I'm guessing 240-250hp judging by the 3+ car lenghts my new bone dead stock 94 Z28 (275hp LT1 w/ a A4 and 3.23s) pulled on it from a standing start to about 80mph. I'd figure you'll run mid 14s maybe, I don't see 13s though w/ the 2.73s especially... I was honestly hoping my old 305 would stand up a little better to my stock LT1 though.
Who knows maybe your fresh rebuild will net you slightly more power and get you some low 14s but I'm doubting it (my old IROC still runs strong), good luck though.
Did you have a particular goal you were shooting for?
Old Nov 30, 2005 | 12:39 PM
  #42
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I dont really have a goal with my car, just keeping it in a nice condition and of course some more power.
I hope to get some bigger runners , maybe a cold air induction and a super or mini ram. And of course a supercharger or turbo.
My tranny works really good, no sliping and the transgo shift kit really made a difference. Im also looking for another rear end something like 3.23 or what i can find. Its better than the stock 2.73.
Old Apr 18, 2006 | 03:18 PM
  #43
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ive been using the car now for a couple of weeks and the new engine runs great. Really made a difference with the new camshaft.
Im very pleased.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
