will this work ???????
Old Oct 20, 2005 | 09:21 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
can I put a accel super ram on a stock 350 tpi with the stock chip and benefit from it ? or will it be 2 much air?
Old Oct 21, 2005 | 10:41 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I can't give a defintie amount, but I would think you should see a gain, especially with the better breating capability about the "wall" stock TPI hits around 4500 RPM.
I just checked for you - Lingenfelter claims a 15-20 HP gain on a stock motor but I don't know if the chip was stock altho I would assume so for that comparison. Check out http://www.lingenfelter.com for more info on it. Or Summit....
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
