383 TPI Question.
Old Oct 30, 2005 | 08:06 PM
My350Camaro84's Avatar
Car: 1989 IROC-Z
Engine: 383 Stroker TPI
383 TPI Question.
Okay heres my dilemma. this car is made to take peoples money. I've really been planning fully building up this motor but keep TPI so I can play it off as a 305 with work done . I was going to buy the aftermarket intake and runner by edelbrock then get them ported and polished will that open it up alot more?
Old Oct 31, 2005 | 09:12 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Re: 383 TPI Question.
Yeah that'll help, you really think you'll be able to pass your 305 off as a 383?
Old Oct 31, 2005 | 10:23 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
dont see why you wouldnt be able to pass it off as a 305. my 355 with a fairly lumpy cam passed as a 305 that needed carb tuning, after i dropped the idle down WAY low. opened the hood, he saw CARB legal headers, an Edelbrock 1405 with the choke wired open, shiny new Performer RPM intake, and mismatched paint on the engine. poor little Mustang never knew what hit him.
Old Oct 31, 2005 | 10:36 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
I bet that was great...
I guess it would be fairly easy to pass it off wouldn't it...
Old Nov 1, 2005 | 10:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
as far as that goes you can pass off a 400 or even a 415 SBC as a 305...
BTW, Lingenfelter offeres a 420SBC L98 conversion for only $22,485.
John
Old Nov 2, 2005 | 03:38 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
You would need to get them extrude honed to really open them up.
Old Nov 2, 2005 | 11:36 AM
BadSS's Avatar
I'm going to try and pass off the 11:1 406 roller motor topped off with a modified FIRST unit (which looks a lot like the stock TPI) I'm building for my MCSS as a 305. Hopefully they'll think I'm totally nuts for running 1.875" diameter headers and dual 3.5" Borlas on a 305TPI.
Ok,,, I'm kidding about trying to pass it off as a 305, but the first engine I had in the SS (back in 1987) was an internally balanced 406 with Dart II cast iron heads. I was running a 7525 Wieand intake (low rise single plane with EGR), stock valve covers, tricked out computer controlled quad. It was mild, ran 13.2s on the engine and I had a 150 shot (dropping it to 11.8s) with the solenoids painted black and the lines from them to the plate covered in rubber hose and a wire loom covering the nitrous feed line,,, that I added wires to and taped up inside the loom. I had a guy point to the solenoid once and ask what it was,, I said dude,,, with all that emissions crap under there,,, you're going to have to tell me what it is. He gestured that he didn't know and said lets do this. I didn't consider that as a lie back then,,, although it surely was deceitful. Since I didn't have to spray the guy, I didn't feel too badly for taking the cash. I won a lot of money with that set up.
To get back on subject,,,, that FIRST Injections unit would be a good "trick" intake. Looks close enough to pass off to most non-tpi guys as a TPI and with mods can support a serious engine. Its $1000 with throttle body,,, which isn't too bad considering a good base runs $375, runners are upwards of $300, and a T/B cost around $300. On the cheap, porting the stock base and modifying a set of SLP runners will give good results for the money,, assuming you've done a little porting before
Old Nov 2, 2005 | 11:42 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
John
thats a ****load of money
Old Nov 2, 2005 | 01:51 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
If you want good flow and still look stock get a set of arizona speed and marine large tube runners and a tpis bigmouth intake. At a quick glance it will look like a stock TPI. The edelbrock stuff screams modified.
Old Nov 2, 2005 | 02:23 PM
okfoz's Avatar
I have considered the GM motorsports 383 Long Block engine with the fastburn heads, get the Scroggin Dickey Vortec base and put my oversized runners on...
If done right no one would be wiser...
John
Old Nov 2, 2005 | 02:57 PM
John
fastburns are aluminum tho right? anybody can tell the difference between aluminum and iron heads. Modified vortecs would be a better option if apearing stock were the goal.
Old Nov 2, 2005 | 02:59 PM
okfoz's Avatar
paint the aluminum black...
John
Old Nov 2, 2005 | 04:26 PM
I spoze that would work. I was just thinking about what would make it look like an unmolested stock motor that had never been out of the car. A painted block and heads would be a red flag to me if was looking at a motor. I may not think they were Aluminum but I would know that the motor had been messed with.
Old Nov 2, 2005 | 04:29 PM
okfoz's Avatar
stand back 10 feet throw rocks at it, and then take some dirt mixed with used motor oil to spray on the engine, then wipe it off best you can so it looks like its been in there a while.
John
Old Nov 2, 2005 | 06:03 PM
oh... ok ya got me
Old Nov 2, 2005 | 09:17 PM
Car: 1989 IROC-Z
wow guys thanks for the input. I'm not sure how I'm going to pull off brand new AFR heads as. well. old just realized that. anything else with great flow but I can either port the **** out of or I can just get new that don't look so. spiffy? as I said this motor needs roughly 500 ft/lbs of torque then it's going to be sprayed. any other helpful hints?
Old Nov 2, 2005 | 09:45 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Just don't paint the block and heads after the work is done. Most of the time they'll still have some patina left.
Old Nov 2, 2005 | 09:49 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
500ft lbs of torque!?!?!??!?! what are you doing trying to reroute the planets? holy hell!
Old Nov 4, 2005 | 08:38 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Better upgrade the tranny, and rear end....
Old Nov 4, 2005 | 08:51 PM
Car: 1989 IROC-Z
got a moser 12 bolt with a built T56. so driveline and rear aren't a prob. dont' forget it's going to be on juice =D. unless I see 500 ft/lbs. motor then I'm going to put a supercharger on it. which I'd rather not do
bdads
Aug 24, 2015 06:01 PM
wruiz
Aug 13, 2015 09:07 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
