adjust throttle body
Old Nov 9, 2005 | 06:07 PM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
How do I adjust the throttle body to idle higher? IN my beretta i could just adjust the screw but behind the screw in my 2.8 it's flat metal..i know this has to be possible....Mine idle's a little too low..and this kid my dad knows has a firebird that idle's WAY too high.
Old Nov 9, 2005 | 07:13 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
My first response is to tell you to find out why they are doing this.
After that I'd suggest at a minimum a repair manual before you go adjusting screws that are sealed from the factory.
Old Nov 9, 2005 | 08:35 PM
LD1985's Avatar
Engine: 3.1
repair manual? I have them. I searched it and every one seems to be adjusting theirs on here. I'm sure it's a vacuum problem but will not be able to tackle this untill thanksgiving..Meanwhile my car dies at stop signs and the like.
Old Nov 10, 2005 | 09:48 AM
Vader's Avatar
Before adjusting anything:
  • Be sure the throttle body is clean;
  • Check all vacuum hoses for damage;
  • Make sure the IAC and its air passages are clean, and the IAC pintle is able to move along its rack gears. You can search the archives here to find instructions detailing the cleaning, lubrication, and installation of the IAC;
  • Another item that is critical to closed throttle air flow is the PCV valve. These valves actually have a calibrated pintle and springs to assure proper air flow under varying vacuum conditions.
Aftermarket PCV valves sometimes fall short in this respect. Using a clean OEM PCV can correct some of these problems. I had a nasty episode on a V-6 that was traced to a FRAM replacement PCV valve after having to replace the EGR, IAC, checking the FPR, ignition, and a load of other items - All because the aftermarket PCV was calibrated incorrectly. One new AC PCV valve later, everything was back to normal.
italiano67
Dec 11, 2016 09:21 AM
db057
Sep 4, 2015 07:57 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
