tpi head question
Old Nov 10, 2005 | 08:33 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
tpi head question
Will the newer 081 heads bolt up to a block that came with the older 416 heads? I know one is from a roller 1 piece motor and ther other is from a 2 piece non-roller block.
Old Nov 10, 2005 | 08:57 AM
I have an intake from an 89' if the the only problem is how the bolt holes line up on the intake
Old Nov 10, 2005 | 09:09 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The heads will bolt to the block. You may need to modify four of the intake base's bolt holes to get the middle bolts to hold the intake to the heads. Pretty much any SBC head will bolt to a SBC block.
Old Nov 10, 2005 | 01:09 PM
So if i use a later style TPI lower intake, i wont need to modify anything?
Old Nov 12, 2005 | 01:20 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yes you'll need a drill. You have to make sure the 4 middle bolt holes line up from the intake to the heads.
Old Nov 12, 2005 | 10:16 AM
how is that? The extra 89' lower intake i have was originally bolted to 083 heads which has the same bolt patern as 081 correct? I dont see how they wont line up.
Old Nov 12, 2005 | 02:19 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
On heads that came off a one piece roller block the inner 4 intake bolts are vertical to make them easier to get at. The older 2 piece style they where angled the same as the outer bolts.
Old Nov 12, 2005 | 04:21 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You were mixing model years with casting numbers, so that was unclear what you were wanting to do. If you already had the answer then why ask the question?
Old Nov 12, 2005 | 04:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes to answer the original question. i believe it was already answered.
Old Nov 12, 2005 | 06:27 PM
sorry for the confussion. I guess I was just concerned that an intake from a 1 piece engine woudnt work on a 2 piece block w/ 1 piece engine heads (081). There is some sort for metal sheet that bolts on to the newer intake over the lifter valley that isnt on my older intake.
MustangBeater20
Oct 29, 2022 09:20 PM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
