89 formula stalling problems
Old Nov 24, 2005 | 12:09 AM
92camaroRS25th's Avatar
i have a 89 formula 350 tpi 74k orig miles.....
it was sitting for somewhere in the lines of 6 years....
i go to start it. no crank VATS problem, i put the usual new lock cylinder and key and it fired right up... now i have a check engine light that blinks on then off when it blinks it stutters coughs and sometimes backfires... when its on steady its not so bad. when its off she pulls hard and runs good i pushed on the prom and the light turned off i have a loose starter wire.. i saw in one of the posts a guy said his starter wire was the problem. its not the wire with all the fuseable links on it its the single wire i want to know if that is the problem? or it is a definate prom issue, sometimes i can hear the motor in the speakers... and the voltage drops down a bit, lights dim and it runs like total crap any words of advice? even starting problems sometimes cranks no start
Old Nov 24, 2005 | 09:59 AM
Vader's Avatar
Re: 89 formula stalling problems
Originally posted by 92camaroRS25th
...i pushed on the prom and the light turned off...
There's little doubt that you have some connection problems at/in the ECM. Disconnect the battery and start checking there first.
i have a loose starter wire.. ... sometimes i can hear the motor in the speakers... and the voltage drops down a bit, lights dim and it runs like total crap any words of advice?
Repair the starter wiring. You should also check the grounds on the engine and chassis. Those symptoms indicate a connection problem. The noise heard in the speakers could also indicate a failed diode in the alternator, and you may want to check that as well. Don't just start replacing parts, but analyze them first.
Old Nov 30, 2005 | 10:15 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take the wires of the injectors one by one. after taking off one wire start the car if it runs better then you have a bad injector and it is gounding out. You can also check with a multimeter all injectors should be around 16 on resistance scale
92camaroJoe
Jul 29, 2023 07:57 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
