AFPR Help
Old Dec 29, 2005 | 10:44 AM
link85x's Avatar
Car: 1988 IROC-Z
Axle/Gears: 10-Bolt w/3.08's (dying)
AFPR Help
Hey everyone, i was wondering if getting one would help with a little performance gain on my 305TPI. I have Edelbrock TES Headers, w/a AMT Catback. How exactly do you use the AFPR and which is a good one to purchase?
Old Dec 29, 2005 | 11:42 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
AFPR
Located about halfway down.
A: The stock setting is 42 PSI. Much track testing has showed that any type of increase will greatly benefit both horse power and torque. Here's some dyno testing on a stock 350 motor which substantiates those claims:
42 PSI (stock) 46 PSI 50 PSI
RPM Torq HP Torq/diff HP/diff Torq/diff HP/diff
2250 237.7 101.8 254.9/17.2 109.2/ 7.4 275.0/37.3 117.8/16.0
2500 241.7 115.1 262.1/20.4 124.8/ 9.7 283.3/41.6 134.9/19.8
2750 241.5 126.5 275.2/33.7 144.1/17.6 297.0/55.5 155.5/29.0
3000 237.1 135.4 278.2/41.1 158.9/23.5 305.5/68.4 174.5/39.1
3250 233.8 144.7 278.9/45.1 172.6/27.9 311.3/77.5 192.6/47.9
3500 241.0 160.6 278.2/37.2 185.4/24.8 309.5/68.5 206.3/45.7
3750 246.6 176.1 283.4/36.8 202.4/26.8 303.3/56.7 216.6/40.5
4000 250.4 190.7 278.3/27.9 212.0/21.3 298.0/47.6 227.0/36.3
4250 251.6 203.6 272.5/20.9 220.5/16.9 289.1/37.5 233.9/30.3
4500 253.5 217.2 257.3/ 4.2 220.5/ 3.3 277.0/23.5 237.3/20.1
4750 245.0 221.6 242.1/-2.9 219.0/-2.6 266.4/21.4 240.9/19.3
5000 227.6 216.7 225.0/-1.4 214.2/-2.5 237.8/10.2 226.4/ 9.7
It shows that by increasing the fuel pressure to 50 PSI, results in maximum torque increase of 58 ft-lbs (along with a much flatter torque curve) and a maximum horse power increase of 19 HP over stock. 46 PSI also provides a noticable increase which should work well for day-to-day street driving. An adjustable fuel pressure regulator (see Chap 5.2) is required to increase the fuel pressure.
Old Dec 29, 2005 | 12:43 PM
link85x's Avatar
Car: 1988 IROC-Z
Thanks, it's exactly what i was looking for. Any suggested AFPR to pick up?
Old Dec 29, 2005 | 01:38 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
if you're going in for an AFPR def go for the Holley brand, i've heard its the easiest to use out of all the other companies that produce the afpr's for our cars, its a tad bit more expensive but worth it in the long run.
-nikh23
They all are pretty good. Ive never used any so i cant tell you.
Old Dec 29, 2005 | 01:46 PM
link85x's Avatar
Car: 1988 IROC-Z
Thanks.
Old Jan 3, 2006 | 06:16 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I would recommend a Holley APFR, you can adjust the FP by hand instead of using a wrench. I had to add three small washers for the bottom 3 screws so that I the screws would be tight, and I had to take a little metal off the side so it would fit properly. Once that was all done, it has worked well in the year and a half I've had it on.
Old Jan 5, 2006 | 07:53 AM
link85x's Avatar
Car: 1988 IROC-Z
Thanks, i'll be getting the Holley one then.
Old Jan 5, 2006 | 09:19 AM
Vader's Avatar
I've had fairly good luck with mine. Being able to adjust by finger is not a concern to me. Once the pressure is set correctly for the programming and setup, it should never need adjustment.
Mine was about $1.35. It may be as high as two dollars now, with inflation:
AFPR Conversion.pdf
Old Jan 5, 2006 | 04:28 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Vader, i have asked a few people before but no one has answered my question.
About what MAX FP is possible with a DIY pressure regulator?
Old Jan 5, 2006 | 05:09 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If u can duplicate what that chart shows for a simple fuel pressure change, I will eat my shorts and bow to TPIS.
lol
I can promise u that will not happen, not now, not ever.
Advertising is great isnt it?
later
Jeremy
Old Jan 5, 2006 | 07:35 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I believe it but......it is an illusion. You can say stock 350 and let the court open for ALOT of variables. ie. Stock 350, AFR heada? Stock 350, XE274 cam? Stock 350, 12:1 CR? and etc. etc. etc.
Old Jan 6, 2006 | 12:13 PM
link85x's Avatar
Car: 1988 IROC-Z
Where can i get most of the items? From home depot? I'll try this 1st. It wouldn't hurt. What is the max psi you can set the dyi with?
Old Jan 6, 2006 | 12:14 PM
link85x's Avatar
Car: 1988 IROC-Z
Sorry 91gta, you just asked that question.
Old Jan 6, 2006 | 07:37 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I have asked it SEVERAL times yet i still wait on a answer.
Old Apr 4, 2006 | 01:26 AM
Camaroz29's Avatar
Originally Posted by 91GTABird
AFPR
I don't think you can gain hp with the only variable being increased fuel pressure either. I am interested in increasing the fuel pressure to get the most out of a set of injectors though. I wonder what the safest amount you can run is? I have the Holley AFPR.
Old Apr 4, 2006 | 03:52 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I'm about at 50 PSI with vac without it's like 55-57 my car seems to like that better then that recommanded PSI everyone says. I don't even need to drive it to tell, i just kick open the throttle and it revs much faster then the recommanded and sounds just flat out stronger .it kinda has me thinking i might have 19lb injectors rather then the 22lb that vettes normallyl come with, my chip is setup for the 22lb so this might be whats goiing on my end?
Old Apr 4, 2006 | 04:18 PM
Camaroz29's Avatar
Most injectors are advertised at 43.5 PSI, so if you up to 50 PSI it is like you are running larger injectors. www.racetronix.com shows you how much they flow at 43.5 and at 58.0 PSI.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
