Engine progess
Old Jan 11, 2006 | 12:28 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Engine progess
Finally got around to hiding and splicing all of the wires. Just ordered some cool bowtie spark plug wire loom for my valve covers. Can't wait to get it. Hopefully she'll start up friday when I get my fuel rail AN fitting from holley.
For those that do not know, the car origionally was equiped with a 305 TBI. It's now 350 with a SR runned by a 165 computer. What do ya think so far?
Old Jan 11, 2006 | 12:31 AM
Dirtbik3r's Avatar
Old Jan 11, 2006 | 12:35 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I bet your giddy in your pants to see all your work payed off, especially since the last motor you had is child's play considered to what you have now.
Old Jan 11, 2006 | 09:17 PM
Dirtbik3r's Avatar
Ya I am... Can't wait to start her up. I waiting on the spark plug loom from summit and a fuel line barb from Holley.
Old Jan 11, 2006 | 09:53 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Good luck That'll really wake her up. Nice car btw.
-Schultzy
Old Jan 11, 2006 | 10:17 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Sweet set-up. I wanna do the same thing, i got the L98, now just saving for the stealth ram and a TB. Good luck
Old Jan 11, 2006 | 10:40 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
Lookn good. You gonna dyno it?
Old Jan 13, 2006 | 12:09 AM
Dirtbik3r's Avatar
Put the hood on today. I'm having some clearance issues between the underhood support and the tpi intake ducting(2into1 piece). So the hood kinda crushes it and slightly bends upon closing. Anyone else have an issue like this? Looking for a quick fix because come next fall, thats gonna be functional ram air.
Firing her up depends upon the stupid fuel barb fitting arriving in my mailbox from Holley. Since I dont have a y pipe yet, gonna make by dad drive with me (NYPD cop) so I dont get pulled over for being to loud.
Old Jan 13, 2006 | 07:15 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Stealth ram
Engine looks awesome!! I do have a question though I am doing the same thing (HSR) to an 86 Camaro and I was wondering what part number you upper radiator hose is. I am having some difficulties finding one that fits. Thanks for your help.
Old Jan 13, 2006 | 08:47 PM
Dirtbik3r's Avatar
I used a '92 305 TBI hose. Fit perfect. Just remember the tpi water necks are different.
Old Jan 14, 2006 | 12:35 AM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
wait, wait, it's becomming clearer now.......ah yes.......i predict some serious azz whoopins in your future.
Old Jan 19, 2006 | 12:32 AM
Dirtbik3r's Avatar
Alright, these were taken today
Old Jan 19, 2006 | 12:33 AM
Dirtbik3r's Avatar
Heres another:
I do have a problem getting it started. I have spark and fuel. Something is funky with the distributer. Look here if you wanna know.
https://www.thirdgen.org/techbb2/sho...hreadid=341541
Old Jan 19, 2006 | 01:48 AM
stealthrocz's Avatar
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
i also have a similar set up, just wanted to ask a few questions about the swap. first did you use factory vortec intake gaskets or the fel-pro 1255. the fel pro's look pretty thick. secondly the car is a factory 5.0L 5-speed what can I expect with factory chip in regards to the 5.7 vortec swap. just waiting on my fuel rails and I will be doing some wrenchin. thanx for any info
Old Jan 19, 2006 | 01:56 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Vortec swap
Stealthrocz, your probably wanting dirtbik3r input, but let me tell you what I did. I used the "factory" fel-pro gaskets, in my opinion the 1255's are too thick and as far as your chip goes, was your 5.0L the TPI or TBI and what size injectors are you planning on running, the inj size is gonna be your biggest hurdle if everything else is the same.
Old Jan 20, 2006 | 12:55 AM
Car: 87iroc
the car is tpi and if it dont run right after my swap looks like i will have to buy new one commander 950 or the painless ecm . i am pretty sure my injectors are 19's and will try to upgrade in the near future. thanx for the info
Spyder_TheGamer
Dec 25, 2015 05:07 PM
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
