New Ride Has Problems
Old Jan 17, 2006 | 12:37 AM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Just picked up a '91 Z that was in need.
Has some running issues.
Just spent my first day looking over the car.
Idle is constantly searching up ad down.
While driving it will die when you push in the clutch.
Loses power bad when reving up.
Check engine light stays on and occasionally flickers.
Computer controlled cooling fan runs constantly.
Will not flash trouble codes.
Light stays on when checking for codes.
Computer has been replaced at one time.
Old Jan 17, 2006 | 01:15 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
ECM and possibly one or more sensors are probably bad. Car is most likely in limp home mode (hence the running bad and SES light).
Old Jan 17, 2006 | 08:56 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
make sure they didnt replace the ECM with a automatic one. If you get the #'s off of it they should be able to track it down to see where and what it came off of.
Old Jan 17, 2006 | 09:08 AM
The computer number is 16198262.
According to Standard Ignition Products catalog it fits:
90-92 Camaro 5.0-F engine
90-91 Camaro 5.7-8 engine
Prom should be different for auto and manual.
Also discovered that it has an ADS Superchip in it.
The AIR system has been removed.
Don't know what affect that had on drivability.
The speedo doesn't work either.
Can't figure out why it won't flash diagnostic codes when I try to pull them.
Old Jan 17, 2006 | 05:13 PM
Shagwell's Avatar
Car: projects.......
if the ADS is a piggy back, drop it off and see how she runs. also, check for a vaccum leak.
Old Jan 17, 2006 | 09:03 PM
That was next on my list along with cleaning the IAC valve.
Old Jan 19, 2006 | 01:02 PM
Pulled the super chip today.
Car now has a working speedo, idles, fan quit constantly running, and will go into diagnostic mode.
Still goes real flat revving up.
Took a trip around the block and it has not thrown a code yet.
Feels like the timing is being pulled out or it is starving for fuel revving up.
Old Jan 19, 2006 | 04:42 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Faulty/bad fuel pump and or fuel filter
OR
Detonating really bad and ECM is retarding the crap out of the timing.
OR
bad gas, try running 93 octane from a good gas station
OR
pick-up module in distrib. is going bad
............ just some ideas to look into.
Old Jan 19, 2006 | 05:19 PM
Shagwell's Avatar
- check base timing. - as in unplug the est, and check w/ timing light. start around 6(stock). Many people crank the timing on these cars because..."it'll make it faster"...to much timing can easily make it "faster" to the trailer...
Old Jan 19, 2006 | 08:47 PM
Guy who had it before me replaced the distributor and fuel filter.
I have been easy on putting too much gas in it for the fear of it being the fuel pump.
I have put 93 in it and it was almost empty when I got it.
customblackbird
Aug 15, 2021 10:16 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
neekolzun
Aug 24, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
