Cut this out?
Old Jan 18, 2006 | 05:50 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Cut this out?
Hey guys, Im just wondering if you think it would be beneficial to cut out this part. Im guessing it would allow more air flow, I'm just wondering if its worth the time and something I should do. If so, should I cut the whole thing out, or just pop a few more holes in it.
Old Jan 18, 2006 | 06:14 PM
Shagwell's Avatar
Car: projects.......
not gonna make noticable difference in power, but not gonna hurt anything. Its designed like that because most Camaro's had the battery on the passenger side.
Old Jan 23, 2006 | 07:37 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If you drive the car in the rain alot, I wouldn't do it. Water on your air filter is...
Old Jan 23, 2006 | 08:50 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
With the front air dam and inner fender cover in place you would be hard pressed to get water up into that area. Lots of folks cut that out for their cold air intake.
-Schultzy
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
