anyone have good results
Old Jan 18, 2006 | 07:41 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Hey gang:
I am building an engine and before I button everything up I thought I would make sure others have had good
success with this same combo. I am a little concerned that I might need a modified eprom
thanks again for your replies.
355 with 10.5 compression
world products sportsman II 2.02/1.6 64cc angle plug heads
comp cams 12-423-8 .502/.510 110 lobe separation 106 centerline
224/230@.050
hydraulic roller
88999194 ecm with 16068654 chip
accel 24lb injectors and tuned runners
1.52 roller rockers
87 gm tpi maf with 58mm throttle body
slp 1-3/4 headers
3.73 gear
700r4 2400 stall
Old Jan 18, 2006 | 08:48 PM
brutalform's Avatar
If I were you, I would pick a more ECM friendly camshaft. Try to keep the LSA at a minimum of 112. Unless you really want to jump into DIY prom, and tune away, because, that combination will definatley need tuning. Only more complicated with the 110 LSA. Those cylinder heads are not a good choice for a TPI engine, IMO. Maybe try a Brodix, or AFR, TrickFlow, etc. The MAF will be more forgiving than a S/D system. Might need a converter that stalls @2800, but with your gears, you might get away with the 2400. BTW, did you mean "large tube runners"?
Old Jan 18, 2006 | 09:44 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Great engine, mismatched induction. That's a great HSR, MiniRam or SuperRam motor. LTR's are going to choke it very very badly.
backtothe80s
Sep 5, 2015 12:39 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 12:39 PM
jahblah
Aug 12, 2015 05:54 PM
djmarch
Aug 9, 2015 05:27 PM
