Throttle Body question
Old Jan 17, 2006 | 09:37 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
well ive done a search but am still a little confused cause i saw so many different answers. Heres the deal. Im gonna put an HSR on my 350 and i need a throttle body cause i sold my stocker tpi stuff. My car is a '91 so it is SD. my question is, will it be ok to use an aftermarket accel throttle body from a MAF car. is the only difference the throttle cable attachment or would i need to make other mods?
Old Jan 18, 2006 | 12:58 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
anyone?
Old Jan 18, 2006 | 01:36 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Well I am not really sure but since know one else replied I will take a shot at it. I have an Edelbrock catalog that sells throttle bodies for 85-88 tpi cars, and 89-92 tpi cars. Since the 89 cars are MAF and the 90+ cars use SD it looks like it would be ok beacuse they are both under 89-92 cars, that includes MAF and SD.
Old Jan 18, 2006 | 02:20 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
so i would prolly just need a different throttle cable at should be fine huh?
Old Jan 18, 2006 | 02:22 PM
Car: ws6
Engine: ls1
Transmission: m6
Thats what I was thinking. What else have you seen when you did a search?
Old Jan 18, 2006 | 02:55 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I've read (dont remember where I read it) that you can use '85-'88 TB on '89-'92 systems but not the other way around; I'm not sure if this would still hold true when using the HSR as they only have one plenum design.
Old Jan 18, 2006 | 02:59 PM
Car: ws6
Engine: ls1
Transmission: m6
I think you will be fine. Just get a diff tb cable......later
Old Jan 18, 2006 | 03:03 PM
Duts87ss's Avatar
I agree.
Old Jan 18, 2006 | 06:21 PM
Shagwell's Avatar
Car: projects.......
after owning both, the only difference I know of is the throttle cable. The later-models have the progressive linkage, and the older models have the straight hook up.
Old Jan 18, 2006 | 08:22 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would just order the correct throttly body. In your case the 1989 to 1992 cars. The above are correct in that the throttle cable attachement is way different. Why pay extra for a throttle cable and the pain to install it? While you are at it might as well get the 58mm version for you HSR.
Old Jan 18, 2006 | 08:36 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Isn't the TPS non-adjustable in the later models?
Old Jan 18, 2006 | 08:38 PM
Car: ws6
Engine: ls1
Transmission: m6
I dont think so
Old Jan 18, 2006 | 08:44 PM
Car: 86 T/A
Engine: HSR 355
I must have read that wrong somewhere.
Old Jan 18, 2006 | 09:23 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
the only reason i wanna use an older model is cause i found a good used one for 200 instead of frickin 300 for a new one
Old Jan 18, 2006 | 09:26 PM
Car: 1989 GTA
Engine: 369 TPI
On the 1990 and up models (read MAP cars) the TPS is non-adjustable unlike on the 1989 and earlier models. You can bend the tab for adustment or buy the earlier style sensor. If you get the older model don't forget to factor in the price of a different throttle cable and the installation.
Old Jan 18, 2006 | 09:53 PM
Car: 86 T/A
Engine: HSR 355
Originally posted by 1989GTATransAm
On the 1990 and up models (read MAP cars) the TPS is non-adjustable like on the 1989 and earlier models.
Shazam! I was right.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
