24lb/hr or 30lb/hr injectors?
Old Jan 20, 2006 | 11:45 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
What is a good baseline to know what size injectors to run?
You can see the mods to my motor in my sig.
Right now I have a set of 24lb/hr and 30lb/hr injectors.
Some people are telling me to run the 24's and some say at WOT the 24's will fall flat on their face.
Any thoughts on this?
The multiplier I found for injector size stated the 30's would be used for up around 500hp. That seems to be a bit much hp for a 30lb injector, although, I could be totally wrong.
Old Jan 21, 2006 | 12:19 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i dont think u will see enough rpm's with that tpi to warrant 30#'ers
24 should be fine.
Old Jan 21, 2006 | 10:44 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
www.geocities.com/scwizzo/graph.jpg
There's a graph I made to show how much horsepower injectrs can take. 24lbs can handle around 350 hp at 85% duty cycle before they get above that. 24lbs should be good for you.
The equation you use to find out is http://www.geocities.com/scwizzo/equations.html
Old Jan 21, 2006 | 10:50 AM
TKO500's Avatar
That is great information. How about throttle body size? Would you recommend stepping up to a 52mm or staying 48mm?
Old Jan 21, 2006 | 10:59 AM
Car: '94 Z28
Engine: LT1 350
I don't think you'll see an increase going bigger. The 48mm can handle around 635 cfm pretty easily.
Your engine is maybe seeing 520-550 cfm. Usually people don't step up to bigger throttle bodies until they hit the 400 hp mark, or if they have a blower. A 52mm can handle about 770 cfm, in my opinion it'd be overkill.
Old Jan 21, 2006 | 11:10 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'll let you know more after today's dyno session. I'm putting down 322RWHP with 24# injectors and currently at 75% duty cycle and running rich. So when the final tune is in I will post the RWHP and injector duty cycle. How efficient your engine is and the BSFC has a part with the injector size.
Old Jan 21, 2006 | 11:13 AM
TKO500's Avatar
That would be awesome. I will wait to see your results!
Old Jan 21, 2006 | 04:12 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
When I built my 406 I used a stock TPI with ported stuff and I programmed the 90 F-body computer for 24lb injectors.. it ran with a serious bog so I tried increasing the fuel pressure this helped but it still had a bog.
I then installed 30 lb ACCEL injectors and this cleared the problem right up.. I know I could use more in the way of TPI tubes, manifold, etc but the injectors made all the difference in the world.
Old Jan 21, 2006 | 04:42 PM
TKO500's Avatar
I am going to take a guess and say that your 406 is putting out a ton more horsepower than I am with my 350.
With my motor combo I think I am going to be in the window of 350chp. I have had one engine builder tell me to run 24# injectors and another told me to run 30# injectors.
The one that told me to run 30# said I should run those because at WOT as I pull into the higher rpm ranges the injectors will pretty much be saturated and it would hurt my performance.
The one that told me to run the 24# injectors said that I will only exceed the limitation of the injector if I build the motor more or run NOS or a super charger. I have no plans of doing either so I am really leaning towards staying with the 24's. Regardless, I do have a set of 24's and a set of 30's.
Old Jan 21, 2006 | 08:57 PM
Car: 1989 GTA
Engine: 369 TPI
I can tell you I'm up to 330RWHP with #24 pound injectors on my 350. I know the duty cycle was under 80% but will get the details later.
Old Jan 22, 2006 | 12:38 AM
dbtk2's Avatar
Car: 1986 Trans Am
Engine: Carb'd 305
Axle/Gears: 10 bolt, 3:42's
At 85% duty cycle I made 230fwhp in my V6 with 22lb. injectors. (and thats spinning up to 6200) So with two more injectors, and all the injectors 2lb/hr. bigger, I'd say 24lb should be plenty, especially since you have TPI so you shouldn't be spinning it nearly that high.
Shawn
Old Jan 22, 2006 | 11:57 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am still running my 24#/hr FMS injectors in my 395 cu.in motor, but at 52 psi fuel pressure.
With your current mods, 24s is all you need, and you should not require a Eprom change.
If you install an AFPR and run the 24s at 56 psi (where they will flow about 28#/hr), you should be able to make 400 Hp at the flywheel.
Old Jan 22, 2006 | 12:42 PM
TKO500's Avatar
This all some great information. I did forget to list in my sig that I do have an afpr. I suppose I will be putting the old 30#'ers up for sale
Old Jan 22, 2006 | 12:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what brand are they.
Old Jan 22, 2006 | 12:59 PM
TKO500's Avatar
My 30's are FMS injectors.
Old Jan 22, 2006 | 01:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
how much u want for them?
i need a second pair.
Old Jan 22, 2006 | 01:42 PM
TKO500's Avatar
I sent you a PM
Old Jan 22, 2006 | 03:23 PM
Car: 1989 GTA
Engine: 369 TPI
Further update. As stated above I'm putting down 330RWHP. That is with the 24# injectors at 43.5 pounds, and 80% duty cycle at 5700 rpm. So I still have some wiggle room as I can crank the pressure up to 50#. However with the next go around I will be putting in the #30 pound injectors. Looking for a big horsepower increase and I'm at the edge of the 24 pounders now.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
