AC delete on non serpentine 305 !?
Old Jan 24, 2006 | 08:19 PM
86IROCer's Avatar
Car: 1986 IROC-Z28
Transmission: Boring Automatic
ok, ok. I have done a search already, and I cant seem to find any answers for a non serpentine 305 tuned port injection. Everything seems to be for a serpentine driven IROC. Now, is that because it's as easy as just removing the belt and related items since there are other belts to drive the power steering and such? Or is this a little more involved? I would just want to get rid of the compressor and canister, just leaving thre box alone. Any and all thoughts are much appreciated.
Old Jan 24, 2006 | 08:24 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
take the belt off, take the pump off, get rid of the lines and condenser, get yourself a non ac heater box...youre done
Old Jan 24, 2006 | 08:54 PM
86IROCer's Avatar
Car: 1986 IROC-Z28
I thank you very much for your quick response! It is very appreciated. I will be doing that tomorrow. Just out of curiosity, has anyone here done this yet?
Old Jan 24, 2006 | 09:03 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
i did it on my 85 monte carlo ss when i had it and i put my 350 in. just pulled the pump and everything right off. only thing i did different was i removed the whole ac and heater unit totally cause i only drove it in the summer.
Old Jan 25, 2006 | 12:10 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Ive done it, just go to work and rip everything out.Took me a couple hrs or so.Theres not much to it. The only thing you need is a shorter belt for the crank/PS and if you want the heater to work get a heater box like stated above.
Old Jan 25, 2006 | 01:04 PM
86IROCer's Avatar
Car: 1986 IROC-Z28
I am confused as to why I need a shorter belt for my ps and crank. Isnt there a belt that already drives them both?
Old Jan 25, 2006 | 03:53 PM
JDubya18's Avatar
Engine: 305 LB9
oh sorry, I think I got confused there. I did the smog pump delete at the same time and thats the one you need a smaller belt for. lol It was a while ago. sorry about that
Old Jan 25, 2006 | 06:13 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
i didnt buy any new belts...
Old Jan 25, 2006 | 06:55 PM
JDubya18's Avatar
Engine: 305 LB9
lol dont ask me. I thought you needed a belt for one of them. Im just confusing myself though. Ill have to check it out to remember.
Old Jan 25, 2006 | 08:22 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
you need a shorter belt if you wanna delete the smog pump on a serp car without using the delete pulley, maybe thats what youre thinking of
Old Jan 25, 2006 | 08:40 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
V belts setup are easier. Just remove the compressor and belt and all lines connecting to it, remove them.
If you can't find a non a/c box, if im not mistaken you can just remove the lines to the canister and plug that.
Old Jan 26, 2006 | 03:35 PM
86IROCer's Avatar
Car: 1986 IROC-Z28
I just wanted to thank everyone that has helped me out with this problem! it is greatly appreciated!
Old Jan 26, 2006 | 04:04 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The a/c belt runs in the second groove on the power steering. It can be removed leaving one belt from the crank to the ps pump or replaced with a shorter belt to wrap the crank/wp/ps. The second belt just provides some back up in case one is lost/thrown/destroyed. Just cheap insurance.
I live in South Carolina. It's against the law to remove A/C down here.
j/k.
evilstuie
Jan 9, 2020 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
