What 30# injectors are best
Old Feb 12, 2006 | 10:56 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
I'm going to need 30#'rs for the 383, I see the Accels for 250 bucks. Is that the way to go? Bosch's are like 400 and that seems a little steep if it's the same. But are there others?
Old Feb 12, 2006 | 11:03 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Do not buy Accel. Go on ebay and look for Ford SVO injectors. Part# M-9593-B302
Old Feb 12, 2006 | 11:15 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
205 bucks on Summit, not bad. And these are a direct swap? I am having the software updated again so thats no problem.
Old Feb 12, 2006 | 11:20 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Yes
Old Feb 12, 2006 | 11:24 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Thank you VERY much.
Old Feb 13, 2006 | 01:07 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
wish I'd known that. I bought the Accel 30# injectors from Summit. They're kinda loud. When I started up the motor, I thought I had lifter, rocker arm adjustment problems (hydraulic roller!) until I put a stethoscope on the injectors. It's pretty noticable. I wonder if the Ford injectors are quieter.
Old Feb 13, 2006 | 02:14 AM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
I have the FORD 30# injectors there not much louder than stock 22's
Old Feb 13, 2006 | 02:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Definitely the SVO/Ford racing 30#'s.
They tend to have a little more noise than stockers but arent too bad. Depends on how loud everything else is on the car really.
Lots of issues with fols and accell injectors, I've also seen them fail when still fairly new/low mileage.
As far as the SVO's go, I have seen them come with 2 different 0-rings on them. The second type are slightly smaller than the GM type and I would recommend replacing them with GM equivelant 0-rings.(set them side by side and u will see the difference). Other than that, u will be ready to roll.
later
Jeremy
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
