accell 8.8 cause stumbling?
Old Feb 14, 2006 | 04:50 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
anyone ever have this happen? on a bone stock 87 305 tpi. no arching that i saw. resistance on all wires is good.
Old Feb 14, 2006 | 05:32 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I dont run any accell ignition products as I think they are junk.
I have had issues with their plugs, wires, caps ans rotors.
They never lasted compared to something like MSD wires, Delco plugs and the blue/copper terminal blue streak caps.
This is my opinion.
U may or may not have a wire fully seated and it could cause a partial or intermittent miss. Plug loosen up on ya? It does happen especially if u dont tighten them emough in the first place.
Make sure you have the firing order right?
later
Jeremy
Old Feb 14, 2006 | 05:36 PM
brutalform's Avatar
If you end up replacing the wires, use dialectric grease on both ends, and, I always use MSDs self vulcanizing tape on both ends, where the boots and wire meets. Just some cheap assurance against voltage leaks.
Old Feb 14, 2006 | 05:37 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
Did ya change the spark plugs along with the wires?
Old Feb 14, 2006 | 05:40 PM
brutalform's Avatar
Nice wittil wabbit.
Old Feb 14, 2006 | 07:18 PM
Shagwell's Avatar
Car: projects.......
3.8TransAM - I fully agree. I went through 3 sets of 8.8's in 3 weeks trying to get a set that worked. This was back and forth w/ Jegs. Stumble, cross-fire, miss-fire...etc. I'll never run anything of theirs again. - A buddy of mine bought a set of their factory fit wires for his 96 truck. Pre-built, factory crimped ends and he had 2 dead cylinders. He went back to regular old Delco's and he once again had a V8.
JUNK! MSD all the way.
Old Feb 15, 2006 | 12:45 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
used dielectric grease and triple checked firing order, and used rapid fire plugs, ended up going back to a stock replacement wire and everthings working fine! i will have to try out some msd stuff, any suggestions on wires?
Old Feb 15, 2006 | 03:05 PM
brutalform's Avatar
Now, I have always used Accel 8.8 wires, and have had good luck with them. Except for an occasional header burn, no real issues. I always use the universal set. Never tried the custom set. Maybe when you buy them assembled, there are issues. Not saying thats right, or anything, they should ALL work.
Old Feb 15, 2006 | 05:46 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i have always used Accel 8.8 wires, never had an issue with them, the only thing i see as an issue is that the pre-made kits always seem to be a tad bit short in length
i also like MSD's wires, they are nice too
I'll never but Taylor again, I have used a few of them and so have some friends, and they have been nothing but crap, bad quality, pulled apart easily, arching, etc..
Old Feb 15, 2006 | 06:29 PM
joeyg329's Avatar
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
i always liked moroso blue max wires... 50 bucks for a set and never had a problem and they look good. Right now i have regular accel wires on my camaro and i noticed a little bit of misfire but at this point it could be anything...
Old Feb 16, 2006 | 08:40 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
My MSD wires are still on the car from two plug changes now, but my Accels were dead after before the next change.
I know, I know, change the plug wires. I'm working on it.
Old Feb 17, 2006 | 08:56 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Accel Wires
I run MSD, pretty expensive, but they are quality imo.
Old Feb 17, 2006 | 09:13 PM
brutalform's Avatar
Originally posted by 87TPI350KID
Accel Wires
Over the years I've used Accel, and MSD. I'm not brand specific.
Not to get off topic...but...
NHRA, top fuelers use MSD 8.5s. I wonder why would anyone put anything larger on their ride?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
RedLeader289
Sep 23, 2015 06:50 AM
