twin turbo stock 305
Old Feb 14, 2006 | 09:35 PM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
hi, i am purchasing a twin turbo intercooler header set for my all stock 305 TPI and i am just wondering if this is safe for my lower motor. please let me know if this is a mistake and if my crank will send pistons through my heads. will it be fast?
Old Feb 14, 2006 | 09:37 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
not a mistake if you keep the boost low with a reasonable tune
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
For some reason I have a feeling this will be a very fast car. I will meet your crank in saudi arabia when it gets there.
Old Feb 14, 2006 | 09:38 PM
thanks guys, will it beat SRT-4's
Old Feb 14, 2006 | 09:44 PM
nicks89ws6's Avatar
Car: 89 ws6 formula 5spd
Engine: 355 4bolt mains afr195's stealth ram
Transmission: t-5
Axle/Gears: 3.08 open diff lol
twin 305
if you can keep the tranny together and hook you will scare a lot of people. including ureself
Old Feb 14, 2006 | 09:46 PM
o yeah?
Old Feb 14, 2006 | 09:53 PM
Vader's Avatar
Fast? "Fast" is a relative term.
As for your idea, this is the result:
Smitty's 305 Turbo IROC
Old Feb 14, 2006 | 09:56 PM
Engine: LB9, LB9
Is that a single turbo sir?
Old Feb 14, 2006 | 09:58 PM
WoW thats a fast car, will mine be this fast with twin turbo and intercooler?and maybe tpis top end?like intake and stuff?
Old Feb 14, 2006 | 10:08 PM
what if i put a shift kit in will it hold the 12's and a small cam?
Old Feb 14, 2006 | 10:18 PM
need more info on the stock tpi with twin turbo?please
Old Feb 14, 2006 | 11:52 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Honestly, I think your main concern with a TT setup is strengthening your motor and drivetrain up, because it's going to be handling alot of stress...and lets face it, you won't be babying it anytime soon
As for beating SRT4's...you do the math.
4cyl + 1turbo vs. 8cyl + 2turbo.
You are doubling him in both respects, so 99% of the time, yes, you will spank the hell out of an SRT4, unless it is rediculously worked.
Old Feb 15, 2006 | 12:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Preston Smiths car I take it? that thing so rocks lol I remember whan it was in magazines like 10 yrs ago lol Its a runner.
Your 305 should last just fine.
I would recommend a leakdown and compression test to see how things are.
Run a real management system though.
If u do it nicely I could see 12-15 psi intercooled on it.
Like convert to a sy/ty 749 and go slow and easy on learning the tune. It will pay for itself as well as keep your engine together :-)
Lots cheaper than aftermarket stuff too.
later
Jeremy
Old Feb 15, 2006 | 08:22 AM
Vader's Avatar
Yes, that's Smitty's car. I archived the video as encouragement to all of us "slow" 305 drivers.
FWIW, if you run boost, installing larger runners and plenum is less of an issue.
Old Feb 15, 2006 | 03:22 PM
well im still thinking about the turbo idea so if anybody else has anything else to say about this please do so
Old Feb 15, 2006 | 03:49 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
wheelstandin87 Alittle off topic but what mods do you have in your 89 Iroc to run a 13.4?
Old Feb 17, 2006 | 08:42 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If your having to ask if it will work, you probably won't want to do the install.
It would be a scary fast machine though. Single turbo L98s with stock compression, cam, heads have made some 360 rwp+
Terrell351
Jun 13, 2021 01:13 PM
Grant2k
Jul 10, 2018 04:01 PM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 01:18 AM
Leggman1
Aug 6, 2015 04:15 AM
