Bolting Coil Bracket onto Intake Bolts????
Old Feb 16, 2006 | 10:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a 1991 z28 that had the TPI and now has a stealthram. i would like to mount my coil using the two center intake bolts on the passenger side...
can i remove those two center bolts (intake has already been bolted on), bolt on the coil bracket, and have everything hold up and seal correctly?]
TIA
Old Feb 17, 2006 | 08:08 AM
Vader's Avatar
Only the extreme outboard bolts enter the water jackets. As long as you do not loosen the rest of the intake flange bolts on that side, and torque the bolts back to the spec, you should have no problems. If you loosen all the bolts on that side, simply retorque them all in proper sequence.
Old Feb 17, 2006 | 09:36 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thank You very much!
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Dialed_In
Aug 20, 2015 01:45 PM
