Accel injectors(why no 22lbs)
Old Mar 4, 2006 | 01:40 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I'm looking at replacing my injectors and want to use Accel on my 91 350 tpi. Why no 22lbs made by Accel? So should I go 21 or 23?
Old Mar 4, 2006 | 02:14 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i would go with the svo injectors. heard too many bad things about accel injectors.
Old Mar 4, 2006 | 02:30 PM
Dokken10's Avatar
Car: 91 Formula
What is SVO?
Old Mar 4, 2006 | 02:34 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
yeah , Accell is junk I keep hearing here. SVO is ford injectors. They rate them at a different psi than GM does , so there is a little tuneing needed to optimize them
Old Mar 4, 2006 | 03:02 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Stay away from Accell for injectors.
Get the SVO/Ford Motorsports injectors, its just aname change but the same thing.
Either have to go under by a size or over by a size, most on 350 go with the 24# and a small prom adjustment should make everything fine.
later
Jeremy
Old Mar 4, 2006 | 03:12 PM
Dokken10's Avatar
Car: 91 Formula
What would you recommend for a stock 91 350 TPI and possibly up to 300 hp in the SVO injectors? When you say fine tuning does that require a AFPR? I'm new so please bare with me. Thx.
Old Mar 4, 2006 | 04:41 PM
87zjeff's Avatar
the 24# injectors should be fine. as with any fine tune on a tpi, a afpr should be used.
Old Mar 4, 2006 | 05:25 PM
Abubaca's Avatar
When you change the size of injectors, you need to have a chip burnt for that new size.
The computer thinks it's firing 22# injectors and it knows how much fuel a 22# injector will fire so it makes adjustments accordingly so your car runs correctly. If it thinks it has 22#, but now it REALLY has 24#, the tune will be off and the car won't run right.
Now with 24 pounders, your car will probably run OK, but that doesn't mean you SHOULDN'T get it tuned.
Old Mar 4, 2006 | 05:30 PM
Abubaca's Avatar
An AFPR is NOT needed, although it won't hurt.
A correct PROM tune with a regular pressure regulator may not be optimal for HP/performance, but it's not incorrect.
An incorrect PROM tune with an AFPR is INCORRECT. No matter how the car sounds, it's NOT running like it should.
Old Mar 10, 2006 | 07:41 PM
Dokken10's Avatar
Car: 91 Formula
Thx. for the advice. I'm not going with the Accel injectors.
Old Mar 10, 2006 | 07:51 PM
brutalform's Avatar
I have Accel #36 injectors, for three years now, and have never had a problem with them. I do believe though, its certain flowing injectors that are the problem ones. #22, #24, are the most popular sizes, and they seem to be the "bad" batches.
Old Mar 10, 2006 | 07:54 PM
brutalform's Avatar
Good point, as the engine will run rich, without the injector constant changed in the eprom.
Old Mar 13, 2006 | 11:35 PM
Dokken10's Avatar
Car: 91 Formula
Everyone seems to be recommending the SVO injectors. Is the Summit P/N FMC-M-9593-A302 (that style) the SVO injectors everyone recommends? Thx.
Old Mar 14, 2006 | 12:17 PM
Dokken10's Avatar
Car: 91 Formula
Please help me with my last post?
Old Mar 14, 2006 | 03:12 PM
formul8!!'s Avatar
Car: 2004 GTO
You can run 24# and still be ok. It may run a tiny bit rich, but if you plan on adding more mods, it will need the smidgen of extra fuel anyways.
Old Mar 14, 2006 | 04:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Go with the SVO Pink Top 22lbs They sell them at http://www.fiveomotorsport.com/Injector_Sets.html
I used them and they work excellant
Old Mar 20, 2006 | 08:12 PM
Dokken10's Avatar
Car: 91 Formula
I've read that if you use the SVO on a stock rail you can't use the lock rings. If so, how well do they fit and any leaks?
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
