throttle body
Old Mar 5, 2006 | 06:16 PM
blander66's Avatar
throttle body
What size are the botls on the Throttle body that hold on the TPS sensor, and what size are the bolts that hold on the bottom coolant passage. Also what is the best way to get these bolts out i broke the heads off a bunch of them and the rest does not want to come out
Old Mar 10, 2006 | 10:36 AM
Vader's Avatar
IIRC, the TPS screws are M2.5. The water passage cover on the bottom I can't recall, but I've had mine off and it was no picnic. Soaking in penetrating oil and heat can help. Once you finally get all the screws out, use anti-seize compound when you reassemble, and you won't have that problem in the future.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
