Cam Walk
Old Mar 13, 2006 | 11:33 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Cam Walk
Are these roller cams in our motors known to go bad???
A motor with 157k miles, could the timing chain be worn enough to cause the cam to walk a little.
I have a wierd knock in my motor.
It seems to be tripping the knock sensor and the timing pulled.
No code though.
The most noise using a stethescope is around 1 and 2 and the timing cover.
I had thought of timing chain slapping the cover, but is doesn't really sound like that.
It doesn't sound like the normal bearing knock either.
I don't know how to describe it.
It is vrey wierd sounding and is not even slapping sounding.
I know I am going to have to go through the motor.
I would like to be able to drive it for a while until I decide what course I am going to take.
350? rebuild LB9???
Just not sure what I want to do with her yet.
Old Mar 14, 2006 | 01:30 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Unless something is seriolsy worn out, roller cam engines cant really "walk the cam"
The front has a retainer that bolts to the block.
The rear is held in check by the distributor.
U could get cam walk from a serioulsy worn distrib gear, if the original managed 157k miles.
If the timing chain is original I would consider it highly suspect.
Get something on the crank so you can slowly turn it back and forth(taking the slack out obvioulsy) and watch to see how much movement u get before the rotor moves in the distrib.
Also could have a stud pulling out of the head or a wounded lifter or rocker with that kind of mileage.
later
Jeremy
Old Mar 14, 2006 | 01:50 PM
Shagwell's Avatar
Car: projects.......
If you've got "cam walk" your retainer plate would have to be out to lunch. My bet would be on the chain. Get a decent double roller and swap it out. With 157k it should be done noise or not.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
DARKmj16
Sep 9, 2015 04:07 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
