?'s to finish up my basic tune
Old Mar 14, 2006 | 08:37 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
on my '91 5.7 TPI...
finally, i'm rounding the final curve on this project and have a couple of ?'s regarding compression and spark plug gap. the 1st ? is (for all you guru's) what is my "stock" compression for a 5.7 TPI? 2nd ? is, is it affected by changing the cam and rocker ratio? (now running .525 on the lift, int/exh, w/1.6 rockers) the heads were machined for a 3-angle valve seat, but no "porting" or bowl work. so, with all that said, if my compression is changed, how do i know what it has changed to, and do i need to change the spark plug gap because of that? stock is .035... also, is it normal to find oily threads on the plugs for the first few hundred miles on a rebuilt engine? thanks, i'm about to sign this puppy off, other than tuning on the dyno.
Old Mar 14, 2006 | 10:25 AM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
9.3:1 Cam, rockers, and valve job wont effect it. The plugs may be dirty at first. If the computer dosent get tuned for the cam they will always be dirty and cause a loss of power an hard starting. Pull them out after a hundred miles, check them and clean them.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
69GTOby
Apr 18, 2016 02:34 PM
tyeo098
Nov 30, 2015 06:27 PM
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
