What size injectors
Old Apr 7, 2006 | 09:43 PM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
What size injectors
89 IROC 350 TPI
Stock engine with 9-10 pounds of boost
Stock 22lbs injectors are locking up in third gear at 6-7psi boost.
What injectors would you recommend?
Aeromotive Tsunami Fuel Pump and 8:1 FMU
Old Apr 7, 2006 | 10:01 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
If you've got an idea of the horsepower that your putting out now, you can use the formula: (HP*.5)/(8*.8). This should give you a good ballpark figure.
Old Apr 8, 2006 | 12:33 AM
not real sure maybe 350 at the crank...at the most. I think 400hp is a good goal.
Old Apr 9, 2006 | 10:55 AM
help
Old Apr 16, 2006 | 09:53 PM
ttt
Old Apr 16, 2006 | 10:24 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I have 30 pounders with a vortech 6:1 fmu and stock chip.
Old Apr 22, 2006 | 08:41 PM
we are thinking about 30-37 # ones
Old Apr 22, 2006 | 09:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally Posted by Duts87ss
... (HP*.5)/(8*.8). ...
Math.
(400*.5)/(8*.8) = 31.25
Haven't looked up the formula, but I'm sure a search would verify if the formula given you is correct or not. That said, if you plan on going further than 400, then get the 36 lb. ones and have the appropriate chip burned.
Old Apr 23, 2006 | 09:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would say 42 #/hr (while rated at 43psi), and of course you got to program for it.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
