Having problem with code 43
Old Apr 11, 2006 | 05:34 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I just finished doing a TBI to TPI conversion. But I'm having a problem solving a error code 43 Electronic Spark Control (knock. sensor). I've checked the harness, replaced the knock sensor, tried a different ECU and I have another prom on order so I can test that. The sensor is getting 6.9 votls, more that the specified 4-6 volts, but this voltage was outputted buy both ECUs. Every time I clear the code it returns as soon as the car starts. Anybody have any Ideas? Don't know if it makes a difference, but there are no emission devices currently on the engine. The ECU is a 90-92 730 speed density computer.
I did a search over the weekend, didn't find anything that helped.
Old Apr 11, 2006 | 06:27 AM
Shagwell's Avatar
Car: projects.......
- What's your timing set at? - I've got one to trace down too, I just got a 43 in the Tahoe(TPI'ed)...but I haven't had much chance to look yet.
Old Apr 11, 2006 | 08:10 AM
Axoid's Avatar
Car: 92 Camaro RS
The initial timing is set to 6-8 degrees advanced.
Old Apr 12, 2006 | 08:18 PM
hot 383
Guest
Posts: n/a
DID YOU CHANGE THE KNOCK SENSER THEY ARE DIFFERENT FORM TBI TO TPI I HAD THE SAME THING TILL I CHANGED MINE.
Old Apr 13, 2006 | 12:27 AM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
Check the resistance of the knock sensor. Same here- replaced my knock sensor and got the same code. Turned out the brand new one was defective. Had 90000 ohms of resistance. Picked up another one and problem solved. If thats not it check the wiring make sure nothings cut or broke. If everything else checks good, the end of the diag bubble is faulty ecm
Old May 30, 2006 | 10:52 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
hey guys, im getting a code 43 on my car now too after fixing something else ive been looking at my haynes manual, im still finding my way around the TPI engine bay, can somebody tell me where the actual knock sensor is located ?
any advice or tips on how to clear a code 43 would be excellent too, the GM error codes list shows 3 things that are possibly wrong so im not sure where to start really, knock sensor, TPS out of adjustment or ESC control failure ?
ive recently replaced spark plugs and leads, i also had the cap off the distributor to check the inside to see if it was good (which it was) i put it all back together and the car ran fantastic then 20 mins later coming home my SES light came on and found it was a code 43.
Old Jun 1, 2006 | 01:37 PM
Axoid's Avatar
Car: 92 Camaro RS
It's on the passenger side of the block, low down, just rear of the engine mount. It is best to get to it from under the car.
Old Jun 1, 2006 | 01:45 PM
gta_knight's Avatar
Car: 1987 GTA
thanks a lot. I had the car out today actually and the light never came on once and everything was going nicely, so i think i will leave it alone unless it decides to light up again soon
Old Jun 5, 2006 | 05:03 AM
gta_knight's Avatar
Car: 1987 GTA
ok its back on again !
I was out in the car a lot yesterday around town and i had no problems, but this morning i was goin somewhere where i had to be on the motorway, the car was fine on the way up but coming back my SES light came on, code 43 again.
so im only getting code 43 from motorway driving, 60-70mph in overdrive, what the hell ? around town its perfectly fine
Old Jun 28, 2006 | 03:36 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
im having the exact same problem right now... int town im fine but going over 55 it turns the engine light on, i was told it was my ecm causing the problems ive replaced my knock sensor with no luckthough...... i was told to look at the esc module but i dont know where it is. where is the electronic spark control module located?
Old Jun 29, 2006 | 03:40 PM
IrocZ85's Avatar
MAF
Well guys believe it or not but when a MAF Sensor is starting togo and you has hesitation and stuble from launch I have found code 43 to set off left and right and no other codes and done hours or electrical testing to find out the simplest sensor to check the MAF was bad, figures hope this might help someone as I had running wires as Ive had so much practice through the years
Oh and GTA My car was doing just what you are saying your doing over 70mph situation
Also for fitbmx the module is located on the driverside firewall and if I recall most say hmk on them, Simple find and easy to get to
Old Jul 25, 2006 | 11:35 PM
jstoll's Avatar
Car: 91 Formula
I too am having a 43 code problem. First found tps was bad reading 1.5 at idle. Still 43 on all the time. 2nd found that when I reinstalled motor I have secondary fan and knock sensor backwards. Both have same style plug, if you ground fan out with ignition on fan will turn on. Now 43 is not on all the time but it does trigger while driving. I got 30,000 ohms at knock sensor, timeing at 6 deg. I am kinda lost on this one.
Old Sep 1, 2006 | 04:45 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
Im on the same boat, I drive for about 20 min and my car starts to hesitate, no power, I got code 43. Did anybody fix this problem?
Old Sep 2, 2006 | 06:25 AM
gta_knight's Avatar
Car: 1987 GTA
im starting to hate these TPI engines, always something happening with it. code 43 is nowhere to be found now, instead im getting a code 36 and i dunno where to start with that one.
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
