Timing?
Old Apr 11, 2006 | 04:13 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
Timing?
what should i set my timing too... ive heard 10*-15* is ok but thats a pretty big diff for base timing isnt it? i have a hypertech chip(came with car) and the stock one... i want to do this for the track and i will run 93 octane and porlly octane boost if i need it... what would be best to start at... 10* w/ chip or 15 w/o chip or any combination?... its a lb9 G92 stock but a cat-back and little stuff
Old Apr 11, 2006 | 04:38 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
i know its banned but i guess what i really want to know is how much does a hypertech chip change the timing? and should i compensate for it?
Old Apr 11, 2006 | 04:50 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Unless the Hypertech chip came with instructions to reset the timing, it's probably designed to work the the stock 6* (I think that's the factory setting).
If you add initial timing the ECM is still going to advance the timing to whatever the PROM tells it to until you reach spark knock. I probably wouldnt go more than 10* initial.
Old Apr 12, 2006 | 06:13 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
honestly, it's really all trial and error
i have her car running at 14 base, but i am assuming there is a chip too, because it looks like someone did odd's~ends work to it.
i can see how rapid her advance goes.
octance boost is ...... never mind i wont get into that
i also never get any pinging in her car and we run 93
also the temps in her car are cooler then stock, so that might help
Old Apr 12, 2006 | 08:34 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
That depends from engine to engine. If you decide to experiment, only change the timing with a timing light (you can't set it correctly otherwise), and move it in 2 degree increments.
How big of a difference the Hypertech makes depend on what stock baseline you compare it to. From what I have seen, they add 1-2 degrees, which is not a big deal.
There is alot more into finding ideal timing than the "advance it til it knocks" idea. More advance doesn't always mean you make more power. In addition, you put alot of extra stress on engine internals with every bit of timing you add. Not trying to scare you, just want to make it a point not to run your timing at 50 degrees or something crazy like that.
While I'm on the subject, the proper way to determine knock is with a scantool, or laptop hooked up to the car. You can have knock and not hear it. Actually, if you can hear it, its pretty severe and the knock sensor may not be able to pick it up anymore.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
