wont crank....
Old Apr 20, 2006 | 07:54 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
wont crank....
car: 1989 firebird formula 350 TPI
problem: car will not crank
diagnostics:
1) battery is not yet completely charged, according to the voltage guage it reads 10 volts so far, it is still charging, car was off the road for a while. does the car NEED atleast 12 volts to crank?????
2) car has given me problems in the past with not cranking, then all of a sudden it would crank..... my first guess was the starter solenioid, but its a new starter.....
3) starter relay makes a weird sound after trying to crank the car and it will not crank, the relay gives out a 'DRRRRR' sound, then stops
Old Apr 20, 2006 | 08:10 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
what about Vats?
Old Apr 20, 2006 | 09:24 PM
bigchief's Avatar
no.... i dont think thats it...... just cranked a little, then stopped and i heard the relay go 'DRRRRR' again, im just gonna let it keep charging
Old Apr 20, 2006 | 09:51 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
o, i thought it was total no cranking, soilenoid or relay then i guess, good luck
Old Apr 20, 2006 | 09:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
10 volts is not enough, pop the caps on the battery (if you have them) and I'd bet one cell isn't bubbling while the charger is on.
Old Apr 20, 2006 | 10:22 PM
bigchief's Avatar
alright, but those relay sounds are normal for low power?
edixon24
Apr 13, 2015 03:56 PM
edixon24
Apr 9, 2015 10:34 PM
mitchberry
Oct 26, 2011 10:48 AM
Jlizard
Carburetors
Feb 5, 2009 06:59 PM
