camaro air intake on gta
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I haven't heard of it being done. There would be clearance issues with the hood.
Car: 1994 Trans Am
^^^What he said. Cannot be done. Hood and fender lines of the firebird prohibit us Bird owners from having such a cool intake as the Camaro guys. However, I believe there was one guy that made his T/A hood vents functional, but at the cost of structural ridgidity. <---however the hell that word is spelled. But you are really just better off making your own. I did and it works great.
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
there are def better ways to go.. that kinda looks like it was installed with a chain saw
Car: 1994 Trans Am
I like it, but where does the air come from? I have a '91 and it's pretty sealed up underneath isn't it? I mean the camaro has the fog light holes and the air channels around them. More pics if you have them.
well the arent perfect if i could do it again i would have done it neater ... also it sucks air from where the air scoop feeds up the the radattor .. it make a good diffrence i think
Car: 1994 Trans Am
How much metal did you remove? What two, 6x6 inch squares? I'm seriously considering doing that. Does it hit the hood? Any side profile pics with the hood open/closed?
Car: 89 TA
Engine: 413 TPI
Transmission: TKO 600
I have a friend that put one on his GTA and his hood stays open by a couple inches so he used hood pins. It looks like crap and he getto rigged it in there.
Axle/Gears: 9-bolt/3.45
So as long as the fabrication for the filters and intake is well-done, then the Camaro intake or something else similar in design could probably be done, look good, and work well.
1992 Trans Am
May 10, 2023 07:19 PM
