Which injectors?
Old Apr 28, 2006 | 06:36 PM
Belial's Avatar
Which injectors?
I have a '90 GTA with a 350 L98 bored .030 over. It was a stock rebuild. I need to replace the injectors but not sure on what size to get. I was told to stay away from Accel from a few people and I keep hearing about the ford injectors.
Can someone point me in the direction of these injectors? And will they require any changes to the ecu?
EDIT-
http://store.summitracing.com/partde...=1#Application
will these work?
Old Apr 28, 2006 | 09:34 PM
kevlar8in's Avatar
Im no expert, but I think they are small for your application. 19 lbs came on 305's, while 350 had 22lbs injectors. Stick with the original size injector and no other mods should be necessary. Ford injectors are a great choice I hear, and remember they flow rate them at slighty lower pressure (40) I think, while your furl rail will be pressured at 43.5. shouldnt make mods necessary.
Old Apr 30, 2006 | 04:40 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
go to fiveOmotorsport and look into the "pink" 22lbs injectors, they work good on my ride.
good luck,
joe
Old Apr 30, 2006 | 06:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am still recommending the Ford 24 #/hr injectors, along with an AFPR by Holley. I have been running the FMS 24s since about late 90s, no problems. These are the right sized injections for a 350 or stroker from 250 RWHp on up to 400 RWHp with fuel pressure adjustments.
Old May 10, 2006 | 12:37 AM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
if your looking at injectors to buy I got 24 pound injectors for yea...they have about 10k on them, and worked when I took them off...I'll ship them to you for $75 bucks Just PM me
Oh and I reqimend 24 pound injectors if you go any bigger you might be too rich. There is also the matter of what your going to do to the car...if your going with a bigger cam? exhust? just things to keep in mind. Because if your going to mod it up the butt you might want to get bigger injectors than 24 pounds just so that you don't have to buy an extra set.
Oh yea only one problem...at least you may think it is a problem...they are accel injectors. I never really heard anything bad about them...then again i haven't heard anything good about them...just letting you know.
Last edited by myfast3rdgen; May 10, 2006 at 12:40 AM. Reason: Automerged Doublepost
Old May 10, 2006 | 12:32 PM
Shagwell's Avatar
Car: projects.......
stick with 22lb injectors. They'll support 400bhp no problems and they'll work 100% proper without changing the computer programing.
Old May 10, 2006 | 06:59 PM
JB22's Avatar
Is that the Bosch 22lb injectors that look pink on their website?
Bosch Injectors - 0280150561 D9B-22lb
8/Set: $239.50
Stupid thing is they have the same set in a different area listed as:
8/Set $298.50
Bosch 22.5lb - NEW
0280150561
Flow-matched Set
Old May 10, 2006 | 11:40 PM
kevlar8in's Avatar
Not sure about the pink ones, but the price difference belongs to the fact that one set is flow matched while the other is not I suspect.
Old May 11, 2006 | 10:47 AM
joejoe's Avatar
Car: red one
8/Set: $239.50
8/Set $298.50
Bosch 22.5lb - NEW
0280150561
Flow-matched Set
yes, I got mine for about $215, goto E-gay look under there name, find the injectors you want get the E-gay # for that item call them and they will sell them to you at that price.
Old May 11, 2006 | 07:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thats the wrong part number: for a 350 you want FMS part # M-9593-A302.
The A302s are 24#/hr injectors,,,, the C302s that you show are 19s,,, you definitely want the A302 for a 350,,, and while you are at it, itstall a Holley AFPR.
Old May 11, 2006 | 09:47 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
I've never had any problems with accel inj whhen it comes to returning bad ones lol!
Old May 12, 2006 | 12:50 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
go with 5.0 motorsports, they have stock TPI 350 injectors listed, car passed smog after new injectors from them and runs smooth
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
