A few questions
Old May 7, 2006 | 11:51 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
A few questions
Hey guys! i'm new to the tpi scene. I have hooker 2055 header and a hooker aero chamber exhaust that i want to put on my 305 tpi (its a 5 speed) would i NEED to tune the computer after that or would it run pretty good without any tweeking. Also what size is the stock 5 speed tpi 305 cam and are the heads on this any good or would i be better off with a 416 casting?
Old May 8, 2006 | 07:45 AM
phoenix305's Avatar
no one?
Old May 8, 2006 | 09:53 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
The headers and exhaust will not force a custom tune but you will always benefit from it if it’s done right.
Old May 8, 2006 | 12:25 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The cam is .433I/.415E Duration at @.050 is 207I/214E lobe seperation is 117 degrees. The stock heads are as good as 416 castings so changing them will not help.
Old May 8, 2006 | 04:42 PM
phoenix305's Avatar
thanks i appriciate it.
Old May 8, 2006 | 09:55 PM
phoenix305's Avatar
I just got to thinking would i need a tune if i did 1.6:1 roller rockers and the exhaust and does anyone know how the rockers would affect duration if i did? Also what are the advantages, if any, of switching to bigger injectors. sorry to ask so many questions but i'm trying to learn all this tpi stuff asap so i can get started.
Old May 9, 2006 | 11:47 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you don't need new injectors , untill you get into new heads and cam . There are some great stickies up top you should read.
Old May 9, 2006 | 05:06 PM
phoenix305's Avatar
i have read the stickies but thanks. so if i get an aftermarket cam i will need bigger injectors? and does anyone know about the rockers?
Old May 9, 2006 | 11:05 PM
phoenix305's Avatar
anyone? i dont want tobe asking a bunch of newbie questions but its the only way i'm gonna learn this any help wold be appriciated.
Old May 10, 2006 | 12:28 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You do not need larger injectors until you have 325+ HP. A new cam will not need new injectors. The 1.6 rockers will work fine they will increase the valve duration a little.
Old May 10, 2006 | 08:24 PM
phoenix305's Avatar
will the rockers force a computer change?
Old May 11, 2006 | 07:54 AM
phoenix305's Avatar
ttt
Old May 11, 2006 | 02:36 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
don't think so . But ANY change to the motor can benifit froma tune
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
