EGR solenoid question
Old May 12, 2006 | 12:34 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Aside from the bracket that attaches it to the manifold, is the egr vacuum solenoid for a TPI the same as one for a TBI? They both appear to be very similar with exception to the bracket. If so I could save myself a few bucks on my TPI swap.
Old May 17, 2006 | 08:38 AM
Vader's Avatar
They are functionally identical. As long as you can mount it, it will work the same.
Old May 17, 2006 | 04:10 PM
Mongoose's Avatar
Car: 90 Formula
That's good to hear. I went over the wiring diagrams in my factory service manual and even the wire colors are the same albeit reversed. I figure I could snip the connector off my TBI harness and splice it into my TPI harness and just match the colors. Is the IAC valve the same as well? I looked at them up close and the TPI valve seems to have a slightly larger cone and the opening for the cone in the TB is also slightly larger as well. The wiring is identical though.
jklein337
Sep 19, 2018 06:23 PM
Out-Cast
Sep 3, 2015 09:05 PM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
