STILL NOT IMPRESSED
Old May 12, 2006 | 01:24 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
STILL NOT IMPRESSED
1988 formula 350
afpr 47 psi
headman headers and y-pipe
IMCO muffler
2100 stall converter
Heavy duty tranny, (From eatmyshift.com)
march underdrive pulleys (set of 3)
cold air in take
ram air hood
proxi kumo 4's
posi rear
It ran a 9.4 in the 1/8 mile with a passanger and I only ran once.
Im not impressed at all.
does that sound right, i put alot of money in this car and i figured i would be at least high 8s in the 1/8 wtf!
what do i do? is it worth puting more money in?
Old May 12, 2006 | 01:29 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Whats the state of tune?
Whats the 60ft time?
Whats the 330 time?
Lots of variables.
Is it even the original motor?
and so on?
later
Jeremy
Old May 12, 2006 | 01:35 PM
Engine: l98 350 tpi
original motor 350 tune port
I'm at my moms house right now
the time slip is at mine ill get it saturday.
I just changed plugs and wires autolite*
not changed computer at all.
You live in indiana? I'm in muncie right now and live in indianapolis.
exact 1/8th time was 9.45
Old May 12, 2006 | 02:41 PM
3.8TransAM's Avatar
Check out the NW IN/Chicago Board under regional forums.
Having a Thirdgen Fest up here on May 27th? (think thats the sat of memorial day)
U've got to get everything in tip top shape for u can say if its good or bad :-)
later
Jeremy
Old May 12, 2006 | 02:48 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Your 60ft was probably like a 2.05-2.20, and the passenger didn't help either.
Get some tires or practice your street tire launches by going to the track on test and tune nite twice a week and you should be cutting 1.8x 60fts, which will help. ET is about traction. A 9.45 is about a 14.8 in the quarter. You just have to dot your i's and cross your t's as far *** optimizing what you have now and you will get to high 8's.
Old May 12, 2006 | 08:03 PM
transbird86's Avatar
Car: 1986 trans am
Engine: 383 hsr
Axle/Gears: 3.70
try getting some better runners slp or as&m, also get a custom chip and you'll be surprised from the gains, i dropped 2-3 tenths with a custom chip, and 1-2 tenths with the runners.
Old May 12, 2006 | 08:35 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Passenger could slow you down about a tenth or two, I believe the rule of thumb is that for every 100lbs is one tenth off your ET.
your 60ft most likely sucks, some drag radials would help that greatly, also I dont see much susspension mods done to your car either. You got to plant that power to the ground if your going to go anywhere.
What about your elevation? The higher you are the slower you go, you may have to adjust your time for the elevation.
Old May 12, 2006 | 09:21 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Don't look at E.T at the moment. What was your trap speed in the 1/8 mile? Thats the true indication of how much power you're making. If you want something to compare to. I just have headers, stock 2.77 rear, stock catback with an 80 series, stock tranny, no free mods yet, and I ran a 9.33@76 MPH.
Old May 12, 2006 | 09:24 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Nah...3rd gens are garbage...you should give the car to me...
seriously though, its worth it to get more out of it. Suspension upgrades and gears help tremendously.
Last edited by CreepingDeath94; May 12, 2006 at 09:26 PM. Reason: Automerged Doublepost
Old May 12, 2006 | 09:55 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
we sprayed a stock suspension camaro with a mild 350 with a 150 shot went 11.05 121.
Old May 14, 2006 | 10:01 AM
Engine: l98 350 tpi
the fastets 1/4 mile time was a 14.6 with a 1/8 mile around 9.6
That was before the tranny and with a small exhaust leak.
I figured since i have a 2100 stall i would break torque it up to 1700 rpm.
I think i'll try 1200 rpm and see what happens.
I dont have all that much money right now because it's costing me 700$ to piant it. I'm going to lincoln tech for autobody and they charge 30$ a paint hour there which is a good deal. I payed for that with my tax check. I'll have that done soon and post pictures.
And the suspension on it sucks.
What is trap speed?
i'll have to find all my time slips.
Old May 14, 2006 | 05:29 PM
Engine: l98 350 tpi
60 foot time:
2.124
1/8 Mile ET:
9.431
1/8 Mile MPH:
73.91
1/4 Mile ET:
14.755
1/4 Mile MPH:
92.96
Here is one my car ran with out much done, just cold air intake and muffler
Old May 14, 2006 | 10:07 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I don't know whats up with all these 350's putting up slow times (driver?) but my 305 TPI ran multiple 9.1's @ 81 at my local 1/8th. Motor only had Headman 1 5/8 shorties and a single 3" exhaust w/a Ravin muffler. If I didn't have extremly heavy chrome wheels and could drive I'd be all over 8's. I've never gotten anything better than a 2.2 60 ft. either.
I even hit a 9.4 once missing third!
I'm not trying to sound like a jerk by any means but when I started to look at others times I began to think my motor was a total freak...totally stock insides, unmolested 081 casting heads had never been off the motor.
Old May 14, 2006 | 10:36 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
What kinda posi is in there? Sure it's working right?
Old May 16, 2006 | 08:47 AM
Engine: l98 350 tpi
I found my slip!
60
2.215
330
6.164
1/8
9.459
mph
74.29
I'm not positive it's full posi, but every burn out i've done both tires spun..
Old May 16, 2006 | 09:54 AM
305q_ta86's Avatar
Transmission: 5 spd
Originally Posted by formula1988
I found my slip!
60
2.215
330
6.164
1/8
9.459
mph
74.29
Well then unless it's the famed 'ice-burnout,' where you're sitting in your highschool parking lot in a lineup at the end of an icy day and the riced integra behind you thinks it's funny to pull the e-brake and spin a wheel for a few seconds and you wanna show him how it's done so you brake stand it and wag your f-body *** all over the place, I'd say yeah, your posi works just fine.
In any case, I agree that you need an exhaust. And maybe better gears. With a 2.2 60' maybe your suspension needs work.
Old May 17, 2006 | 01:02 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
When you do the cat-back, cut off that 2.5 inch headman y-collector and put in a 3 incher.
Old May 18, 2006 | 09:41 AM
Engine: l98 350 tpi
I've got full exhaust, headman shorties
headman y-pipe
all the piping replaced and imco muffler
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Thirdgen89GTA
Sep 18, 2015 09:52 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
86White_T/A305
Aug 17, 2015 12:16 AM
