hesitation sucks please help!
Old May 15, 2006 | 04:38 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
ive been dealing with hesitation and lack of power for some time now, im very determined to fix it now that my friends jeep took me like i was nothing because i hit the gas and it bogged and hesitated then struggled to accelerate lol.
My Car:
1989 Pontiac Firebird
305 TPI Auto 2.73 rear.
so far ive given it a tune up to no help, checked resistance on injectors(all sit at 17 ohms) and checked fuel pressure at idle (43ish lbs i think). the strange thing is this only happens once the car heats up, when its cold ill have a bunch of power and its fun to drive. once the car gets up to around 160+ i have hesitation and bogging when i give it 1/2 or more throttle, if i give it less than that it pulls but once i push it more than that, the car doesnt like to go. im not too sure what else to check and have limited means to solve the problem(being 17 doesnt help lol). any advice at all would be awesome, thanks for the help guys!
Old May 16, 2006 | 01:38 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
do you have any codes?
try checking the TPS (while the motor is warm) to see if it is working right?
Old May 16, 2006 | 01:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Also tape a fuel preasure guage to the window( from the fuel rail ..sharader valve) and drive around , see what the preasure is at while the problem happens .
Old May 16, 2006 | 02:29 PM
gp423's Avatar
Engine: LB9 305 tpi
im not throwing any codes, the tps is brand new and is set correctly, forgot the value but my uncle whos a mechanic set it. ill try the fuel pressure gauge idea thursday when i have some time before work. any special gauge i would need to get? what should the pressure be? at idle? at full throttle? thanks for the help gusy!
Old May 16, 2006 | 02:35 PM
joejoe's Avatar
Car: red one
40lbs-47lbs on the fuel press.
Old May 16, 2006 | 03:26 PM
gp423's Avatar
Engine: LB9 305 tpi
awesome, ill defenitly check that asap thanks for the help, ill report back my findings as soon as i can check. also lets say its below 40, what would i have to check/replace to fix this?
Old May 16, 2006 | 03:28 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Also try checking the ignition module they like to do that.
Old May 16, 2006 | 04:54 PM
gp423's Avatar
Engine: LB9 305 tpi
how do i check the ignition module? i put a new one in when i gave the car a tune up if that helps at all.
Old May 18, 2006 | 04:12 PM
gp423's Avatar
Engine: LB9 305 tpi
ok this is odd, today i went to try to check fuel pressure, and i took the cap that looks like one off a bicycle off, and i couldnt get a reading on the gauge. infact when i took the gauge off i couldnt feel any pressure coming out of the nipple there. am i doing something wrong?
Old May 29, 2006 | 03:21 PM
gp423's Avatar
Engine: LB9 305 tpi
well i finally got the gauge to work with the help of my father. with the gauge on and idling it sits at 40, when i floor it it jumps up to 45-47ish and hangs there, even when i get hesistaion the pressure doesnt drop, now im not sure what to check. any ideas on what would be the next step guys? thanks
Old May 29, 2006 | 11:58 PM
robert1's Avatar
Maybe a vacuum leak? What is it at idle and cruise?
Old May 30, 2006 | 12:55 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
The ignition module is in the distributor .
Old May 30, 2006 | 01:47 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
ignition module... when it gets some heat on it... it will start to do that.... you can have it tested at O'Reilly auto parts or any parts store....
Old May 30, 2006 | 02:25 PM
gp423's Avatar
Engine: LB9 305 tpi
well at idle, out of gear is like 1k-1.2k depending on temp of car, in gear its like 600ish, when it cruises 1-1.5k depending on gear/speed, if im doing 60 its around 1.4-1.5k. idle is always steady, just about never stalls.
now that i think about it, it might be the ignition module. when the cars cold(sit overnight) i put the key in and turn it to start and it starts to turn over immediatly. if i do the same after it warms up and i go to start it, theres a 1-2 second lag before it starts to turn over. not sure if this is relivant but i figured id mention it. i hope its not the module though, its fairly new (2k miles old) any other possibilities guys?
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
