Custom 4" CAI for MAF
Old May 17, 2006 | 09:22 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Here's a couple of pics of something I threw together.
Old May 17, 2006 | 09:26 AM
another.......
Old May 17, 2006 | 09:27 AM
one more.....
Old May 17, 2006 | 10:08 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Sweet. Where does the air filter go? I bought one of those LT1 intake tubes long ago, but couldn't find that blue throttle body to elbow hose that you have, so I sent it back. Where did you find that silicone hose?
Old May 17, 2006 | 12:46 PM
Thanks. The air filter goes underneath the engine compartment right in front of the wheel well. I'll take pictures of it as soon as I get my camera back. I got the blue silicone hose from a freind of mine that works at a deisel truck repair shop. It's a 4X6" cold side hose. You can find one on ebay or do a search for deisel truck tubing.
Old May 17, 2006 | 09:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Nice job. I did something similiar when I had my MAF but went with a 3.5" tube. How smooth is the transition from the LT1 elbow to the MAF? I made up a plastic piece to act like a funnel when I did mine. Glued it to the MAF. Same on the other end where I transitioned from the MAF to the 3.5" intake.
Old May 18, 2006 | 08:33 AM
The MAF actually fit snug straight into the LT1 elbow. All I did was use some gasket maker (The Right Stuff-works great!) to hold and seal the peices together. In front of the MAF I used a 3-4" silicone coupler that I got from EBay.
Old May 18, 2006 | 08:55 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
That looks almost exactly like my brother's LT4 (see sig) intake that he made. I deleted the MAF in the PCM so he has a 4" rubber elbow off the throttle body striaght into a 4" mandrel bend from a diesel truck shop going down in front of the driver side wheel. What good is a 4" exhaust with a 3" intake?
Old May 18, 2006 | 02:00 PM
About 8 tenths in my situation
Old May 18, 2006 | 06:57 PM
Joseph Andres,
Thats pretty nice you picked up .8 with just that intake.
Is your 4" Borla XR-1 a cat-back or a muffler? You have a mufflex y pipe, not the entire system? I'm just looking into different exhausts for my car and am trying to save money without doing a bunch of labor. What is the diameter of your catback? I found that I could custom build a full stainless exhaust with a 3" ypipe and a 4" catback for around $500 in parts. I am just losing the patience to actually do it, after my last project took so long.
Old May 18, 2006 | 07:04 PM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
Joseph...
can you give us that are thinking of doing the same thing a run down on what parts were used and where you got them??
also, I'm guessing you relocated the battery to the rear???
Old May 18, 2006 | 11:11 PM
ttypecamaro,
I picked up 8 tenths at the track because of the exhaust, not the intake. That time I ran I had a SLP cold air induction kit. No times yet with the new intake. Last year I used to run SLP 1 5/8" headers into a Borla Catback with the restrictor plate closed. On a nitrous motor that exhaust set up didn't take full advantage of what I had. Now my exhaust system consists of Hooker full length ceramic coated headers with 1 3/4" primaries, a Mufflex 3-4" y pipe, and a custom 4" catback made by Mufflex Performance into a 4" Borla XR-1 straight-through type muffler. $500 for your scenario is pretty cheap. I'd say go for it. I spent that much in just my y pipe and muffler!
LVZ2881,
throttle body to filter (pretty simple)
1. 4X6" silicone hose from a friend of mine that works at a deisel truck repair shop
2. Trick Flow LT1 intake elbow from Summit
3. "The Right Stuff" gasket maker from any auto parts store.....to seal the MAF into the Trick Flow elbow
4. 4-3.5" silicone reducer from siliconeintakes.com on EBay
5. 4" 16 gauge aluminum elbow, 90 x 6" CLR from Global Tecnology & Engineering Global Technology & Engineering - Solutions for Industrial Equipment (thanks to 1989GTATransAm)
6. 4" K&N cone air filter from Summit
and yes the battery is in the trunk behind the right rear wheel.
Old May 19, 2006 | 12:45 AM
LVZ2881's Avatar
Car: 1988 IROC
Originally Posted by Joseph Andres
LVZ2881,
thanks for that great info, I was thinking of making my own instead of purchasing SLP's kit, and you just saved me a ton of research work!!!!!!
thanks!!!
Old May 21, 2006 | 12:54 PM
hey no problem! Enjoy! And BTW you'll also need a 4" hole saw to cut through the sheet metal.
Joe
Old Jul 8, 2006 | 07:57 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
on the LT1 elbow what is that on the side of it? Some sort of sensor boss or something?
Old Jul 8, 2006 | 09:33 PM
Car: 1989 GTA
Engine: 369 TPI
Yes. It looks like he put a rubber cork in it like I did.
That is the hole for the LT1's Intake Air Temp. sensor. I used a rubber plug and some epoxy to seal it.
Old Jul 9, 2006 | 12:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
looks pretty good. i thought about one like that for my camaro but dont know how i would stretch the maf wiring. i guess i could easily splice new gauge wire in there but figured i would go with the gutted air boxes into homemade ram air.
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
Bigold4x4
Sep 28, 2015 05:21 PM
86White_T/A305
Sep 21, 2015 05:28 PM
