Best Gaskets for Ede Runners
Old May 29, 2006 | 12:37 AM
robert1's Avatar
Hey all. What's the best fitting/lasting gaskets you've found for the Edelbrock HiFlow runners and base? Theirs are $35 from Summit. I'm having a time with vacuum leaks from runner gaskets not sealing well. I've tried TPIS large tube runner ones, other F.I shops large tube runner, and stock ones. Have any ideas? Thanks.
Old May 29, 2006 | 06:53 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Belive it or not the stock gasket will work. I paid $20 for a SLP gaskets and found they were idenical to the stock ones from Autozone.
Old May 29, 2006 | 12:28 PM
robert1's Avatar
Ok, thanks. It will be a lot cheaper too. Did you trim them out for the bigger "holes"?
Old May 29, 2006 | 12:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The ones I used for the "BIGGER"holes were the Mr. Gasket # 146 . They are ment for the bigger runners.
Sure the stock ones "work "but they cut off the flow , so why use them ?
Old May 29, 2006 | 12:46 PM
robert1's Avatar
Dang, they're cheaper and better looking than Ede's! I never thought they even made them. Thanks for the tip.
Old May 29, 2006 | 03:35 PM
DJP87Z28's Avatar
Cut off what flow?? Stock ones are the same size as the Intake openings.
Old May 29, 2006 | 09:36 PM
robert1's Avatar
He means the bigger runners have bigger openigns, and the stock gasket cuts into that is all. They're probably only about 1 1/2" inches or so.
Old May 30, 2006 | 11:18 PM
robert1's Avatar
After a LOT of searching, I found the correct info at that "chevythunder" site. You need TWO driver's side gaskets for the Edelbrock Hi-Flow runners! The smaller ones that go to the intake and EGR passages. They have a nice set of pictures there too. Guess what I'm doing tomorrow.......
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
Royal_Z
Sep 30, 2015 08:45 PM
