Injectors installed. Now idle problem.
Old Jun 14, 2006 | 07:23 AM
LeonardS's Avatar
I finally got the TPI runners installed last night. Buttoned up everything else and started the car. It idles at about 2000 RPM at startup and slows down to about 1250-1300 after a short warm up period. The throttle is against the stop and I did not change any adjustments so what do I need to do to correct the idle.
Thanks for all the help getting these injectors and runners installed. I now have a great appreciation for full time mechanics!!
Leonard
Old Jun 14, 2006 | 12:09 PM
LeonardS's Avatar
With all the knowledge on this board, someone must have a suggestion.
Old Jun 14, 2006 | 12:22 PM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
re:idle
hey, on the throttle body drivers side there is a plug behind the throttle stop take out this plug( re screw driver )then take a star socket and turn the screw counterclockwise this should bring the idle down. also , double check all vacuum hoses.hope this helps,jimmy
Old Jun 14, 2006 | 12:27 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
sounds like you have a vacuum leak somewhere do you hear any hissing? there is also an iac adjustment procedure in the tech articles
Old Jun 14, 2006 | 12:37 PM
LeonardS's Avatar
I am thinking that a vacuum leak could be the culpret because I did not change the setting so you would think it should still idle properly.
It is hard to hear if it has a vacuum leak with it idling so fast. I tried to be very careful with placing all the vacuum lines back in their original position. As tough as it was to get the runners on, I might have pulled off a hose.
So what is a good way to locate a vacuum leak?
Old Jun 14, 2006 | 01:40 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Use a plumbers propane torch (don't light it ) and go around the areas where the vac hoses are and also around the intake plenum and runners. If the RPMs go up you found your leak.
Old Jun 14, 2006 | 01:59 PM
LeonardS's Avatar
Thanks for the tip!!
Old Jun 14, 2006 | 02:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^ Yeap, that works really well. I'd say a vacumm leak myself.
db057
Sep 4, 2015 07:57 AM
mike_c
Aug 27, 2015 04:32 PM
86IROC112
Aug 21, 2015 07:20 PM
perZ
Aug 21, 2015 05:51 PM
justin57
Aug 20, 2015 07:05 PM
