cam installed now wont run....
Old Jun 15, 2006 | 05:15 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
ok i tdc'ed it and its getting spark.... it runs when i spray starting fluid in the throttle body..... but as soon as the starting fluid burns it dies.... fuel pump is coming on... could there be air in the fuel rails or could i have the injector wires backwards... someone help.... been screwing with this all day.....is it possible to cross injector wires???
Old Jun 15, 2006 | 06:26 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
someone please help
Old Jun 15, 2006 | 07:28 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
did you pull the dizzy?..check to make sure your not 180 degrees off.
Old Jun 15, 2006 | 07:50 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
you put the line on the harmonic balancer lined up with the "O" on the timing tab and point the dizzy rotor toward the number 1 cylinder.....right??? if so i already did that...
Old Jun 15, 2006 | 09:32 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
If you're not experiencing any backfiring (and you lined the timing marks up properly), it's safe to say that you're timing is okay. How did you adjust you're valve lash? If too tight, the engine won't even start, let alone run...
But, if the engine runs momentarily by squirting some starter fluid in it, it's more than likely in you're fuel system. How do you know that the fuel pump is being triggered, are you listening for it? Did you check the systems pressure?
Old Jun 15, 2006 | 09:46 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
zero valve lash..... if you let it sit for about 30 min then try to start it... it acts like it wants to start but dosn't.... i'm really starting to hate this car.....
Old Jun 15, 2006 | 10:18 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Did your cam come with a 10 degree advance ?
Things I did wrong on mine.
1. Vavle Adjustment.
2. Tighen Spark plugs
3. Set timing.
4. Firing order.
Old Jun 15, 2006 | 10:27 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
a 10 degree advance???? i just changed spark plugs... checked the dist 4 ****ing times... its making a funny sound coming from the fuel rail by the fpr... this car ran fine until now when i do a cam swap.... the sound sounds like air or something... never made that sound before....
Old Jun 15, 2006 | 11:15 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Like they said, if its starting and running on the spray then you seem to have the cam installed properly, and the timing set correctly, so that leave it as a fuel problem. Just take a deep breath and relax a second. You need to put a fuel pressure gauge on the rail and make sure your getting fuel at least to the rails. Im not sure if you can cross or mix up the injector wires, they should be in some kind of order by length so you should not have mixed them up. Have you tried to just move the dist, a few deg in adv/retard and try again. Keep us updated.
Old Jun 15, 2006 | 11:23 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Forgot Fuel pressure
Old Jun 15, 2006 | 11:56 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
fuel comes out the schrader valve like normal... could it be the regulator... it seems to make a weird noise when i shut the key off...like there is air in it.... so tomorrow i am going to take it off and see what is up... but when you let it sit for 30 min or so it seems to want to run but suddenly dies...
Old Jun 16, 2006 | 01:22 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
There's no air in the fuel rails.
Mine ran like crap at first too, fuel pressure and timing were key. Also make sure that the Battery is fully charged, low voltage will affect the fuel injectors.
That cam is going to make your engine want more fuel. Buy a gauge and measure the fuel pressure. Set the fuel pressure at 44 to 46 psi while turning the engine over with the vacuum line disconnected. Then re-connect the line.
Buy a timing light. Start the engine, then after it's running disconnect the ECM control wire. Now set the distributor for 8 to 10 degrees of initial timing with the ECM control wire disconnected. Now reconnect the wire, turn off the engine, and then restart it.
I'd bet a dollar to a dime that it's too lean. It sits for 30 min and the injectors leak some extra fuel into the intake. You turn the key and it trys to start. Then it dies because it quickly becomes too lean....
My engine had lean pop anytime that I reduced the fuel pressure to 39 psi or less. It likes 48 psi without any PROM mods and I'm using 22 lb. SVO fuel injectors.
Also you might have left off a vacuum line on the Plenum... That would make the fuel mixture even more lean....
Old Jun 16, 2006 | 09:01 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
so i should bump up the fuel pressure....
Old Jun 16, 2006 | 01:15 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Depends on what your running now. Do you have a Adjustable fuel pressure reg?
I bought a Holley one.
But....I'm in the middle of all this to. I bought Edelbrock hi flow runners and intake, ported plenum, Holley AFPR., New cam, springs, roller timing gear, and new cover. So I hope I get it all back and running like it was.
So thank you all in advance The more I read the more it helps me out!
Old Jun 16, 2006 | 11:39 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
IT'S ALIVE!!!!! timing was off..... i don't know how but it was... now i need to fix the intake leak and the timing cover seal leak and fuel needs to be turned down.... other than that it pulls soooooooooo much harder!!!! i would recomend this cam to any tpi!!!!! by the way thanks for the imput....
Old Jun 19, 2006 | 11:19 PM
chevycamaroiroc's Avatar
Car: 87 Chevy Camaro Iroc-z
Engine: 350tpi
Axle/Gears: 3:27 POSI
hey roachjuice i want to purchase a cam for my 350 tpi iroc and u recommened this 1 can u tell me more details on the cam so i can look into it and buy it later on,did it pull much harder how was the end result?and do u have the loopy idle or not i coudnt exactly hear perfectly on the video clip i heard mostly the engine reviing
Old Jun 19, 2006 | 11:56 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
i love the cam... not too lopy.... pulls wayyyyyyyy harder above 3000 rpm.... will post another clip in a few min.
Old Jun 19, 2006 | 11:59 PM
Engine: 350tpi
hey its me again do u have specs or part numbers on the cam for me ?if am interested in purchasing it ok man thanks alot and let me no when u put that new clip ill be here
Old Jun 20, 2006 | 12:04 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
part # is 12-262-4
go to comp cams web site and type that part # in
Old Jun 20, 2006 | 12:40 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
Video - 85 IROC-Z with cam and headers idle
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
