cam installed and running (sound clip inside)
Old Jun 17, 2006 | 12:58 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
http://videos.streetfire.net/video/f...39cbd28345.htm
Old Jun 17, 2006 | 05:50 AM
khayd990's Avatar
have your heads been punched out?
Old Jun 17, 2006 | 01:01 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice.. is that the cam in your sig?? I can't wait to see what my cam sounds/performs like!
Old Jun 17, 2006 | 01:04 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
stock heads...
Old Jun 17, 2006 | 03:29 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Congrats!
It seems that you don't hate your car anymore...
So tell me. Are your heads totally stock? Any machining to accomodate the higher valve lift?
Old Jun 17, 2006 | 04:18 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Originally Posted by mnorton
Congrats!
I know that when I had my Comp Cam with 210/215 499/499 I had to have screw in studs installed
Old Jun 18, 2006 | 12:06 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
no machine work.... should i put the 1.5's back on????
Old Jun 18, 2006 | 04:47 AM
khayd990's Avatar
i asked cam question for my 305 and was shot down because stock heads "can only handle 480" but apparently not..
Old Jun 18, 2006 | 11:07 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
it seems to be doing fine other than the intake leak...
Old Jun 18, 2006 | 12:50 PM
mnorton's Avatar
Engine: 305 LB9 TPI
I think that you can do some kind of measurement to see if there is a problem with the springs binding when the valve is open. I've never done it, but I'd bet that it's pretty simple.
I think that if you do have coil bind, the springs will eventually break. That could cause major engine damage if the loose valve gets pounded by the piston.... I'd hate to see that happen.
From what I've read it seems that stock heads really don't flow any better at .500+ lift than they do at .450 so I don't know that your'e gaining anything by using 1.6 rockers with that cam.
If it were me running that setup, I'd be running 1.5 lifters just to be safe. If you think that changing the cam was a lot of work, wait until you have to replace a ruined piston.... That's a complete tear down.
Old Jun 18, 2006 | 03:09 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I was informed that with my cam that it would pull the stock pressed studs out over time.
Old Jun 18, 2006 | 04:49 PM
Brisk's Avatar
i went with aluminum L98 heads for that reason, it comes stock with screw in studs
Old Jun 18, 2006 | 05:11 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Sounds Awsome! I'm in the process of swapping my cam out also. I have a 305 TPI. I bought a 104224 crane cam. Its got 452/465 lift with 1.5 rockers. But I also bought new springs to match. Its going to be fun.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
