Vortec heads
Old Jun 21, 2006 | 04:34 AM
meefy's Avatar
Car: 1989 formula
Axle/Gears: 9-bolt & 3:45 gears
Vortec heads
I'm looking to upgrade to the vortec head style. I know I need to modify my intake or buy a vortec style intake. My question is this. I have seen 2 part numbers roaming out the for stock GM vortecs, 062,906 I think are the numbers.
What are the differances and which ones are " better ". Also, what other pitfalls
are common that I need to look out for, IE: cracks, warping, brackets not working, ETC. Thanks in advance!!
Old Jun 21, 2006 | 09:23 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am not 100 % , but I 5think one base is for a 9th injector setup , and the other is not.
Old Jun 21, 2006 | 05:06 PM
meefy's Avatar
Car: 1989 formula
I think you are a bit confused
I'm looking for the differance between those two casting numbers of the vortec heads
Old Jun 21, 2006 | 05:40 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
you're probably already are aware but.....
the tpi won't work with you current intake manifold.
of course you could upgrade to a HSR when you do the heads.
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
If you go to the Sallee Chevy message boards, the administrator has a good thread on the L31 heads. Both are equally as good. He says he knows from testing that they are both great heads, and there is no difference. I have both types on different engines, and can tell no difference, even visually.
Also, the vortec style tpi intakes have a vette style egr system if you have to have egr. I got my intake from Street & Performance and they sent an instruction sheet that shows a kit, but I found a vette heat tube that runs over to the #8 header to which you weld a pickup for the tube to bolt to. I used vette headers w/vette tube, and had no problems. Then, I took it all off, and blocked egr. It's not required in GA on older cars. I am installing a Ramjet intake on the other engine. They have the Vortec bolt pattern. You can get S10Wildside to make you a harness if you need one.
Old Jun 21, 2006 | 11:57 PM
Z69's Avatar
Z69
One is for the HD 350 IIRC and has seat inserts on the exhaust.
Some will have a little step left from the insert install.
10 sec on each port with a grinder should fix that.
Old Jun 22, 2006 | 07:31 PM
meefy's Avatar
Car: 1989 formula
Thanks! Thats alot of good info at the Sallee site!
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
