Going TPI need suggestions
Old Jun 23, 2006 | 11:01 PM
ohiothirdgen's Avatar
I bought a complete 350 tpi off a member. Im going to hopefully this winter pull my 350, paint the car and do the engine. I would like to use the stock fuel system. Going to get a set of stock l98 heads. Is it possible to get 1hp/ci or higher with these heads and stock fuel system? I have headers and full exhaust. If not what would be a better combination? Id like to stay as close to the stock tune as possble. Im not going to run EGR or AIR. Any input on what cam I should use with these heads/intake or what cam and heads combo I should use would be a big help.
Old Jun 24, 2006 | 11:15 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by ohiothirdgen
Is it possible to get 1hp/ci or higher with these heads and stock fuel system? I have headers and full exhaust. If not what would be a better combination? Id like to stay as close to the stock tune as possible. Im not going to run EGR or AIR. Any input on what cam I should use with these heads/intake or what cam and heads combo I should use would be a big help.
There's much more to it than that. Dynamic compression plays a huge part when determining what size cam to be considering. Never settle for "peak" numbers, as you want that power to be happening under the curve as well. If you're going to be utilizing L98 heads, what (if any) kind of work will you have performed on them? Let's get an idea of compression and air flow, and then it's only a matter of "when" and "where" you want that power to occur...
Old Jun 24, 2006 | 09:53 PM
Id like to get a set and keep them as stock as possible. Basically what would it take a factory l98 to make that kind of power? I know they made 245 max hp. Is it even possible to do with the heads stock?
Old Jun 24, 2006 | 10:02 PM
Without having work done to the L98 heads, and without installing an aftermarket camshaft, it'll be next to impossible to obtain the numbers that you're after, stock. You might want to consider a power adder...
Old Jun 25, 2006 | 12:41 AM
I think youve kind of misunderstrood what im meaning. I plan on installing an aftermarket cam. Im wanting to know what cams I should consider. Should I go HSR or some other intake of that sort. Things like that. Working off of a stock l98 platform.
Old Jun 25, 2006 | 01:01 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
but still with the heads being stock it will be hard to reach your goal.
1hp per ci will be next to imposiable with the stock heads regardless of what cam or intake you chose.some good porting will tell the tale.the cam and intake combo will be a mater of how much cfms you get out of the stock head. then you could mach that with your cam intake chooce. i dont know what the stock heads flow so i cant really help to much.with even port matching and good cam the hsr would get you pretty close, i think
Old Jun 25, 2006 | 01:34 AM
Too many variables. You're looking to obtain at least one horsepower per cubic inch (assuming RWHP, because that's where it honestly matters). All power lies within you're H/C combination. Starting with an L98 platform (but soon discarding the stock heads), 350-RWHP will easily be attainable. If you opt to go with the stock, untouched heads though, it gets rather complicated...
Old Jun 26, 2006 | 10:52 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Run away. Run far, far away.
Old Jun 26, 2006 | 01:58 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
When the system gets old, **** breaks and youll pay out the wazoo to fix it Good luck!
Old Jun 26, 2006 | 02:02 PM
Old Jun 26, 2006 | 05:17 PM
Thats why I was asking the possibility of these numbers. Ive never dealt with TPI before and was thinking of trying something new for the learning experiance. 350hp is a pretty nice number on a carbed engine and really not too overly hard to obtain.
Old Jun 26, 2006 | 05:21 PM
MattODoom's Avatar
Car: '88 G T/A
For a mild N/A TPI long tube setup, 350hp is a bit hard to get. You will probably have to have an aftermarket base, AS&M runners, aftermarket heads and a nice cam.
Old Jun 26, 2006 | 05:27 PM
What kind of numbers should I look for?
Old Jun 26, 2006 | 05:29 PM
MattODoom's Avatar
Car: '88 G T/A
With stock heads (ported / cleaned up) and stock fuel system ( I assume you mean stock size injectors even? ) and a mild cam you could get 275 or so at the crank.
Old Jun 26, 2006 | 09:37 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
the real story is the numbers.more than hp what are quarter mile times you wish for. hp is just a number a time slip is the real show.
Old Jun 26, 2006 | 09:39 PM
Id like to have a reliable 13 second car. 12's would be nice but 13's would make me happy with street tires.
Old Jun 26, 2006 | 09:42 PM
MattODoom's Avatar
Car: '88 G T/A
I just ran my car sunday. Ported L98 Heads, ZZ4 Cam with 1.6 roller rockers, ported TPI base, ported SLP runners, Ported plenum, shorty headers, no cat, 3" exhaust, cold air intake, underdrive pulleys.
Sounds about similar to what you would like to do to yours.
My ET? 14.57.
That's why I said "run far, far away".
TPI is NOT made for getting good ETs.
Old Jun 26, 2006 | 09:44 PM
Is that with stock suspension and rear? What size rear tires?
Old Jun 26, 2006 | 09:49 PM
MattODoom's Avatar
Car: '88 G T/A
Its on a GTA.
Auminum driveshaft, borg warner 9 bolt 3.27 posi.
Brand new tires, 245/50/R16 Ecsta Supra
Trans has a shift kit and corvette servo (hits really hard its nice)
Rear suspension has boxed LCAs and adj panhard bar. Poly Torq arm mount.
Old Jun 26, 2006 | 09:50 PM
Hehe, not all N/A TPI's though...
Click Here
Old Jun 26, 2006 | 09:55 PM
MattODoom's Avatar
Car: '88 G T/A
Bottom line is if you want a nice fuel efficient motor thats fun to drive around town and makes tons of torque (read: does killer burn outs) then stick with the TPI. You'll have a lot of money into a TPI setup to make it run good ETs
If you're okay losing some low end tq opt for a stealth ram or LT1 intake swap, they will get you the track times and HP your after, while still running smooth and well mannered on the street.
Old Jun 26, 2006 | 09:56 PM
my car is a th350 streetfighter with 10 bolt posi 3.73 lakewood control arms and kuhmo 255-50-16. Would rather have a 4 speed auto but the 3 speed makes the car fun.
Old Jun 26, 2006 | 09:58 PM
MattODoom's Avatar
Car: '88 G T/A
A 700R is a three speed when its in "D".
and it has a deeper first gear... about 3:1.
Old Jun 26, 2006 | 10:03 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
13s with a tpi are not hard at all.tpis base and runners. ported penilum and tb with a matching cam and good tune.that should be good for mid to high 13s
Old Jun 26, 2006 | 10:05 PM
Is the 700r4 durable? (Dont mean granny driven durable) Is the driveshaft the same length as a th350? If so I might do the swap one evening.
Old Jun 26, 2006 | 10:06 PM
MattODoom's Avatar
Car: '88 G T/A
How much does the TPIS base and runners cost?
Stock for stock I dont think theyre quite as tough as a TH350. They can be made so easily. I do not think the driveshafts are the same length, unfortunately.
Old Jun 26, 2006 | 10:10 PM
Lol next question. Would it be worth it? How much does a low mile streetfighter sell for usually?
Old Jun 26, 2006 | 10:12 PM
MattODoom's Avatar
Car: '88 G T/A
I don't know what your trans is worth.
Whether or not its worth it depends on what you use the car for. With a 700R you will get overdrive and electronic torque converter lockup (which is usefull both on the highway and at the track). The 700R probably robs more HP then a 350, however.
Old Jun 26, 2006 | 11:29 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
there were some 350 transmissions made that are the same length as some of the 700s.
maybe you have one of those, only way to know is get under it with a tape measure.
i have been told that a 350 has a 22% drive train power loss, a 700 has 18%.
with its lower first gear, a 700 would make it even more fun to drive than a 350.
Old Jun 26, 2006 | 11:53 PM
Should I look for a stock setup? Or should I spend the cash for an aftermarket unit. I mainly drive my car to and from work. Only raced once on the street and never had it to the track. I plan to do so since The National Trails Raceway is about 3 minutes from my house.
Old Jun 28, 2006 | 02:41 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I disagree .
Anyow . My setup netted my 251/318 to the wheels . Not even tuned yet. It's not hard at all to get into the 13's . Some have done it on stock setups with tuneing and suspesion stuff. Once tuned I plan on about 13.6-13.8 . My heads aren't ported yet either.
Old Jun 28, 2006 | 02:44 PM
What cam/heads are you using? Stock fuel system? Im very interested to know your setup if your willing to share it.
Old Jun 28, 2006 | 02:47 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
crap I forgot the check the sig in my reply . Stock fuel system , stock ( cleaned and flowmatched ..I can't stress how much you need to do this )
Old Jul 1, 2006 | 08:57 PM
What about this setup? Stock fuel system lt4 hot cam kit slp runners. l98 heads cut for 202/160?
Old Jul 1, 2006 | 09:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Oh I don't know about running away from TPI. Let's see what my next round of mods will do.
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
drathaar907
Aug 6, 2015 04:20 PM
