TPI Tune up and Edelbrock TES
Old Jun 24, 2006 | 11:08 PM
350 IROC-Z's Avatar
Car: 1989 IROC-Z
Engine: 350 TUNED PORT
Axle/Gears: 9 BOLT 3.45
How long has it taken some of you to do a tune up on your TPI with a TES or some other system style headers? It seems that the headers are going to make it quite intresting to get a socket on the plugs to change. Also I noticed that the inside of my distributor had a little corrosion on the shaft and around the ICM. Would it be better to replace my distributor of just replace the cap,rotor, and ICM? Chevy distributors are fairly inexpensive. Thanks in advance for any tips that you guys have for this.
Old Jun 25, 2006 | 12:02 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
lol i just did this and i used edlebrock tes headers. they seem to do well but i have not had it out to the track since i put them on. i also had a bad dizzy i would go ahead and replace it mine was old and nasty very corroded and even rusted. when we pulled it it was cracked. i also changed plugs wires cap rotor. ill throw a picture up of what my distributor looked like when i pulled it. the new one was like 100 i would go ahead and get a new one.
Old Jun 25, 2006 | 11:41 AM
350 IROC-Z's Avatar
Car: 1989 IROC-Z
Mine looked about the same. I store it in a dry building and only drive it in the summer. Also how long did it take you to do a full tune up? I plan on going to summit tommorow and getting a new distributor and changing the plugs and wires. Thanks for the input.
Old Jun 25, 2006 | 12:59 PM
Car: 88 IROC
well it took a while for me b/c i bought the cut to fit wires and it was my first time doing them. i did them over at mw66nova's house. it took me 2 hours i think tops. the plugs were easy the cap and rotor were easy. the distributor was a little bit harder b/c you have to go to number one top dead center and then position the distributor.
also get an offset wrench for the plugs that helped so so much you dont even know.
Old Jun 25, 2006 | 03:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
One of the many reasons why I dont recommend Edelbrock headers, the spark plug access is horrible.
Old Jun 25, 2006 | 03:43 PM
Car: 88 IROC
i can get to my spark plugs fairly easy, the driver side is very easy but the passenger side is kinda difficult but no biggie if you get one of those offset wrenches that thing worked wonders.
Old Jun 25, 2006 | 09:38 PM
350 IROC-Z's Avatar
Car: 1989 IROC-Z
Thanks for the reply. When refering to the offset wrench, what degree where you using? What it a 45 or 25 degree angle or something else? I have the motor on top dead center and already pulled the distributor. I just can't believe how corroded it is. I'll keep you all posted on the progress.
Thanks for the reply. When refering to the offset wrench, what degree were you using? What it a 45 or 25 degree angle or something else? I have the motor on top dead center and already pulled the distributor. I just can't believe how corroded it is. I'll keep you all posted on the progress.
Last edited by 350 IROC-Z; Jun 25, 2006 at 09:39 PM. Reason: Automerged Doublepost
Old Jun 25, 2006 | 10:25 PM
Car: 88 IROC
[QUOTE=350 IROC-Z]Thanks for the reply. When refering to the offset wrench, what degree where you using? What it a 45 or 25 degree angle or something else? I have the motor on top dead center and already pulled the distributor. I just can't believe how corroded it is. I'll keep you all posted on the progress.[QUOTE]
i dont know what degree it is but i can look tomaro. and if i cant find out what degree ill snap a pic of it so you can see what im talking about. it helped so much doing mine. i knocked out the plugs in less than 10 minutes from the top! most people with edlebrocks said they have to do some from the bottom...
Old Jun 26, 2006 | 09:06 PM
350 IROC-Z's Avatar
Car: 1989 IROC-Z
If you don't mind, a picture would really help. I picked up the new distributor today and plan on installing it on Wednesday night along with new wires and plugs. Thanks for your help and I'll wait for your picture. Take care.
Old Jun 27, 2006 | 04:47 AM
CrazyHawaiian's Avatar
Car: too many ...
What I did with my TES headers was get a regular spark plug socket, cut it in 1/2 (so its about 1.5" long), and drilled out the center. Now I can slip the socket over the plug with the headers there no problem, then use a regular open end wrench to tighten. Can change all the plugs from the top in 10 minutes like you guys. So easy now. I can take a pic of this socket if you guys want. I think you can also buy the same thing on E-bay (but much cheaper to do your own).
On the distributor, I had similar issues on two of them (first my original, then my friends used one). Just buy a new one, I should have done that from the start.
Old Jun 27, 2006 | 04:27 PM
Car: 88 IROC
do what he said i did this just yesterday and it worked great removing them b/c the offset wrench will work and it will work well but it is a little bit hard to get it all the way down on the plug. here do this go get a deep well 5/8 socket with the end so you can use an open end wrench to tighten or losten the socket. it is an ordinary socket but you can use the socket wrench or an open end wrench, it worked great i would recommend that over the offset wrench like i said b4. sorry for changing my mind on you man but i really did just take out all the plugs yesterday and the way i just told you worked better than the offset wrench. just a heads up.
Old Jun 27, 2006 | 09:09 PM
350 IROC-Z's Avatar
Car: 1989 IROC-Z
Gearwrench also makes those socket sets that have a hole all the way through the socket and ratchet. That really seemed to work well for me. I didn't even think about those until late last night. Changed my plugs,wires and set the distributor and fired it up. It sounds really well, ran out of time tonight to run it down the road. Thanks for all the time and the input.
Old Jun 28, 2006 | 02:51 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
i have the T.E.S. headders, and the acess is horrible, but i just made my own tools for removing the plugs, not all of them are hard to get too......
Old Jun 28, 2006 | 02:55 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I used a regular plug socket and extension on a few and a boxed end wrench and the plug socket on the others.6 and 8 you still have to get from under the car though, well I did anyway.It took me about 30 minutes for all 8.
theshackle
Sep 17, 2020 08:26 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
