Hesitation under load, PCV or vacuum leak at PCV?
Old Jun 29, 2006 | 10:21 AM
dperk's Avatar
I have a large vacuum line run from my plenum's large port between the upper runner area down to the PCV on the driver's side valve cover (corvette L98). I have a problem with hesitation under load and when that's happening I hear a ticking coming from that pcv/line. I'm not sure if it's a vacuum line leak or if the PCV is bad?
Would a pcv problem cause a hesitation under load, or is it more likely that I'm getting a vacuum leak?
Also, what would happen if I plugged off that vacuum port to test, and ran NO pcv? I would think I could block that off and run a breather for a day w/o any negative effects of no pcv???
Thanks!
-darren
gta892000
Aug 11, 2019 11:16 AM
bubbaz28
Sep 18, 2015 02:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Ranbo108
Sep 9, 2015 12:20 PM
