MAF Question
Old Jun 29, 2006 | 08:23 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
MAF Question
whats a good brand & price for a Mass Air Flow Sensor for an 87 Z28 TPI, cuz idk, i see prices from less that $200 all the way to $550
Old Jun 29, 2006 | 08:57 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Before spending a boatload of money on a new maf try changing the relays on the firewall. Unless the maf itself has been physically damaged in some way, new relays will solve most maf problems.
Old Jun 29, 2006 | 09:05 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
ahh, 4 got about that stuff, lol, ill check tah tomorrow, if i cant find ne thing then its definatly gotta get replaced
Old Jun 30, 2006 | 06:50 PM
smccrillis's Avatar
Car: 87 trans am
Engine: 350 tpi
I was about to replace my MAF sensor, but after reading this thread I replaced my relays first. Solved my problem and saved me some $$$.
Steve
Old Jul 1, 2006 | 12:17 AM
net_coma's Avatar
Yeah be sure it really is the MAF....my D/A has two spares that did not correct the problem a TPS corrected.
Old Jul 1, 2006 | 08:36 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
its definatly the MAF, everything i checked had no different affect, also i just replaced the fuel filter today, now i just need the MAf, and to clean the brakes so they dont seize up on me
Old Jul 2, 2006 | 08:28 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
is Granatelli a good brand, or is there a better one out there?
Old Jul 3, 2006 | 09:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
get a delco AKA boush off ebay!
Old Jul 3, 2006 | 10:36 AM
Vader's Avatar
Connect a voltmeter to the MAF output with everything connected and hte engien idlng. The MAF should generate about an 800mV signal. If so, the MAF is probably functioning correctly.
What diagnosis/problems/error codes lead you to believe the MAF is a problem?
Old Jul 5, 2006 | 12:58 AM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
well i took it out, n the wies look fried, looks like it shorted somewhere or something
Old Jul 5, 2006 | 09:21 AM
jamon8's Avatar
Engine: 350 tpi
I think you can buy a new splice in harness connector from napa or something
Old Jul 5, 2006 | 09:46 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^^cohan, Vader is right on target when asking you what would cause you to think that there is a MAF malfunction. Any error codes? Any surging? What are the symptoms? The wiring on just about every connector on my 86's original harness looks fried as well, but it doesn't automatically mean that the sensors are shot along with it...
Old Jul 5, 2006 | 09:52 AM
^^jamon8, you're right. He can re-use the original harness' connector, while replacing the terminals, along with some additional wiring, that can be purchased either in NAPA, Pep Boys, and even Home Depot...
Old Jul 5, 2006 | 10:03 AM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
im checkin napa as we speak, n now im pretty sure its just the terminals, once, i get it ill let u know how it goes, accoriding to my uncle,(cuz it was his car up until last yr, he stopped driving it like 8 yrs ago) he said it needed a new one, but i didnt think so i thought it was just the fuel filter, so i replaced that n it seemed to run better but it still idles just as bad so thats when i took it out to look at it n it loked in bad condition
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
